Each time I connect the IPad I get this dialog box. Does every one get this?
I cancel out but wondered if there was some way to just make it not pop up?
This is a discussion on Connecting The IPad, I Get This Dialog Box within the iPad Help forums, part of the Apple iPad Discussions category; Each time I connect the IPad I get this dialog box. Does every one get this? I cancel out but wondered if there was some ...
When you connect the ipad or and ipod/iphone it shows up in windows as a camera or removable drive. Windows asks you what you want to do.
to stop this from happening just hit cancle then open my computer.
right click on the ipads drive and select Properties.
under the events tab select the option that says "take no action".
Thats it, now you wont get the popup each time its connected.
Thank you MikesToolz. I've done it many times before for other devices but went brain dead on this one.
