Does my Wifi fall in a sleepmode ?? Facetime does not respond
This is a discussion on Does my Wifi fall in a sleepmode ?? Facetime does not respond within the iPad Help forums, part of the Apple iPad Discussions category; Hello, I'm Ruud living in the Netherlands so my english is not 100%, I'm sorry for the spelling errors or some wrong translations from the ...
Results 1 to 3 of 3
    112982
    Oct 2011
    Nedtherlands
    Hello, I'm Ruud living in the Netherlands so my english is not 100%, I'm sorry for the spelling errors or some wrong translations from the Dutch.
    I have bought a Ipad2, everything works splendid exept when I close the cover my wifi connection seems to fall in a sleepmode after some time.
    When someone is using Facetime my Ipad gives no signal but also later on no missing call's.
    When I have opened my cover the Wifi-sign is zero but is building up, after a calle with facetime from me to another person who call's back works fine.
    Other people with Ipad's in my familie and friends group don't have this problem (or not using facetime). I even have bought a new routes (Cisco/Linquedsys) because I have experienced some problems with airprinting with the Sitecom I was using (that problem is solved).
    I have tried a lot of things found on the internet from not putting the brightness on automatic, reboot etc.
    I had hoped with the new IOS thad the problemm would be solved but it is'nt.
    Can someone help me? thanks!
    greetings Ruud
    119 times
    15,248
    When the iPad is in Sleep mode, the WiFi is switched off but the 3G (if you have it) is left switched on - because it uses considerably less power and hence will run the iPad battery down much more slowly.
    112982
    Oct 2011
    Nedtherlands
    Smile Thanks for the response - problem now known solution ??
    Thanks for the response. I have got no 3G, so this is for me an or the problem.
    Is there a sollution to prevent the Wifi to go in sleep mode? It would be very stange that I have to keep everything running because a facetime call will com stread around the day, and te battery would use all its power to keer the whole system running.
    Greetings Ruud
  1. Facetime / Video Call On Apple iPad Over 3G And Wifi
    Last Post: 09-04-2011, 12:26 PM
  2. Replies: 3
    Last Post: 07-18-2011, 04:49 PM
  3. FaceTime and wifi
    By Albob in forum iPad Help
    Last Post: 04-01-2011, 06:39 PM
  4. how do I respond to an ad
    By kathnorm in forum New Member Introductions - Site Assistance
    Last Post: 09-27-2010, 10:33 AM
does facetime work when ipad is asleep
does ipad download in sleep mode
facetime - down - no response
facetime sleep bug
ipad download sleep mode
ipad facetime sleep bug
ipad wifi sleep
ipad wifi sleep mode
