Help I have lost Safari On IPAD 2
This is a discussion on Help I have lost Safari On IPAD 2 within the iPad Help forums, part of the Apple iPad Discussions category; Help! Safari has gone missing, I opened my Flickr account to upload some photos but it wouldn't upload from my gallery something about a missing ...
Results 1 to 4 of 4
    31942
    16 times
    Feb 2011
    Staffordshire, UK
    199
    Help! Safari has gone missing, I opened my Flickr account to upload some photos but it wouldn't upload from my gallery something about a missing token error. I came out of safari and when I went to open it again and it's no longer on my desktop or in my task bar. Is this another bug in IOS 5
    Christine
    A Blind doodler.
    116 times
    15,249
    31942
    16 times
    Feb 2011
    Staffordshire, UK
    199
    Thank you Tim, everything is back again it took three reboots to get it back. I am having lot's of problems trying to upload photo's from my gallery, everything worked fine until I upgraded IOS, I used Icab browser but no longer works.
    Christine
    A Blind doodler.
    580 times
    Dayton, WA
    13,192
    It might take an update by iCab to fix things. Some apps always break after an update, no matter how hard the developers try to prepare ahead of time.
  1. Replies: 8
    Last Post: 10-12-2011, 05:23 PM
  2. Ipad 2 safari vs iphone safari
    By Cyke in forum iPad Apps
    Last Post: 07-10-2011, 10:08 AM
  3. Lost my Ipad!
    By luckyleo in forum iPad General Discussions
    Last Post: 06-12-2011, 02:33 PM
  4. Lost Safari bookmarks
    By Fermendzin in forum iPad Help
    Last Post: 06-10-2011, 03:55 PM
  5. Lost Plus Sign in Safari
    By Portercreative in forum iPad Help
    Last Post: 05-27-2011, 09:34 PM
have lost safari
help - lost safari on ipad
ipad bottom bar disappeared
ipad lost safari
ive lost my safari icon on ipad
lost my safari on ipad
lost safari in ipad
lost safari ipad
lost safari on ipad
lost safari on ipad 2
lost safari on my ipad
safari on ipad lost
