Another sync problem
This is a discussion on Another sync problem within the iPad Help forums, part of the Apple iPad Discussions category; MY IPad still don't look the same as it did in ITunes, no matter how many times I soft reset and hard reset, it won't ...
Results 1 to 4 of 4
    108304
    Oct 2011
    11
    MY IPad still don't look the same as it did in ITunes, no matter how many times I soft reset and hard reset, it won't work out, but I keep downloading free apps, but unfortunately unless someone here give a right clue to transfer or sync to my IPad, they will only stuck in ITunes library
    116 times
    15,249
    I've moved this to the Help section, where I think it will receive better attention.
    108304
    Oct 2011
    11
    Yeah thanks, hoped someone will assist me to solve the problem
    576 times
    Dayton, WA
    13,177
    Under the Store menu in iTunes, make sure your computer is authorized. At the top right, make sure you are logged into the store with the same account that you use on the iPad. If by chance you were logged into another account, hold in mind that any app purchased under another account and synced to your iPad will not update on the iPad unless you also chance it's account invthe store.
    With the iPad connected, select it under the Devices list, go to the Apps section at the top. Make sure that you have app syncing turned on, and that all the apps you want on the iPad have checkmarks next to them.
    If you have apps on the iPad that are not in iTunes, right click on the device and choose Transfer Purchases. Do this be for you sync or turn on App Syncing.
  1. Sync problem
    By Peta in forum iPad Help
    Last Post: 10-04-2011, 01:32 AM
  2. iTunes Sync problem
    By LVSNE in forum iPad Help
    Last Post: 07-04-2011, 09:55 PM
  3. iOS 4.2.1 Sync Problem
    By RayS in forum iPad Help
    Last Post: 12-05-2010, 03:59 PM
  4. Another Photo Sync Problem
    By arjuna108 in forum iPad Help
    Last Post: 09-07-2010, 11:22 PM
  5. Sync Problem
    By Snapp in forum iPad Help
    Last Post: 05-27-2010, 08:23 PM
