Has anyone had an issue where the movies you have on your IPad won't load after the OS 5 upgrade? I have 22 digital copies that are in my library, none will play and the usual cover shots are blank? Any ideas?
This is a discussion on IPad Movies won't Load within the iPad Help forums, part of the Apple iPad Discussions category; Has anyone had an issue where the movies you have on your IPad won't load after the OS 5 upgrade? I have 22 digital copies ...
Hi just had a similar problem. When I click on tv shows I get dumped out. This only happened after ios upgrade. My movies are fine. I am not sure what to do now.
Problem solved. Seems one of the Music Videos was corrupt and it stopped the rest from synching properly.
How did you find which one? what do i need to do to resolve this? i have twelve movies on my ipad and only one will load. Thanks!
