Results 1 to 10 of 12
    111573
    Oct 2011
    8
    Can not sync pictures from my PC to Ipad via Itunes, please help me.
    After ipad and itunes update I can not sync my pic from PC to my Ipad. I have Win7 premium home edition. Nothing helps, I have also deleted the Ipad photo cashe folder, have checked the box to sync the pictures but nothing heppends. The status bar shows that pic are there but nothing was transfered over to my ipad. Please help me urgently, because got to go overeas in two days and would like tomfix this problem. Thank you
    111573
    Oct 2011
    8
    I have reinstalled Itunes ---- nothing changed
    I have deleted the Ipad Photo Cashe ---- nothing changed
    I have checked the pphoto folder settings --- nothing changed
    I still don't know how to fix my problem !!!
    Anybody here please who can help me ???
    Thank you
    19182
    3 times
    Oct 2010
    Israel
    891
    can you put here a picture of iTunes withe the screen showing the folders to be synced.
    It should show a list of folders with a check mark,
    You can also try a 3rd party software like "iMacsoft iPad to PC Transfer"
    iPad to PC Transfer - Transfer files/music/video to iPad
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
    111573
    Oct 2011
    8
    Thx for your repaly, I have checked the box with folders which should be synced but nothing happens. In the bar on the bottom if itunes it shows that 4,2 GB should be synced and that there are 5781 pics to sync. When the sync process begin first itunes make a backup then starts to sync calendars and contacts, syncs apps, and on the next step to sync photos the process of syncing stops, without to sync pictures.
    I would love to have pictures on my Ipad which I had before on my Ipad synced from my PC to ipad. But that works not now. That happened after itunes update and ios update on ipad.
    With my iphone 4 i had no problems to sync it, just with my ipad. I have ipad one.
    Thank you once more
    111573
    Oct 2011
    8
    I have also called apple in Autria, but they dont like to help me because I am from Croatia, and we dont have here a apple call center
    111573
    Oct 2011
    8
    Can not sync pictures from my PC to Ipad via Itunes, please help me.-fotografija-4-.jpg
    Here is the picture you have asked for !!!
    Thank you
    19182
    3 times
    Oct 2010
    Israel
    891
    Un mark all other tabs so that they wouldn't sync - including the Application tab.
    I would suggest to mark "select folders". (see my picture)
    Then you should select the proper folders that includes ypur photos, and sync.
    Try to select a single folder with few photos - just to see how it goes.
    Can not sync pictures from my PC to Ipad via Itunes, please help me.-16-10-2011-19-03-45.jpg
    111573
    Oct 2011
    8
    Thank you peled, I have donte it the way you told me, but still nothing. I have also changed the folder where the pics are and placed it on another HDD but that did not help also ! Thank youmonce more !
    41971
    Charleston, S C
    5
    I have a problem syncing photos with iPad. Problem just started as I have synced many times before. I get a message on iTunes saying that it can not sync because a file is missing. I am able to sync these same pictures to my iPod touch without any problem. What to do
    126107
    Nov 2011
    Milan
    i HAVE THE EXACT SAME PROBLEM
    Quote Originally Posted by thundercollector View Post
    DON'T KNOW WHAT TO DO ANYMORE. see my thread
  1. Replies: 1
    Last Post: 10-14-2011, 10:02 AM
  2. Uploading pictures with itunes
    By johnipad2 in forum iPad 2 Forum
    Last Post: 10-11-2011, 12:07 AM
  3. I cant sync my pictures
    By Saf in forum iPad Help
    Last Post: 09-25-2011, 04:16 AM
  4. I need help with pictures and itunes
    By artemisblossom in forum iPad Help
    Last Post: 11-18-2010, 05:51 AM
  5. Replies: 1
    Last Post: 06-16-2010, 09:20 AM
how to fix ipad photo not showing
how to sync pc tp ipad
how to sync pictures from pc to ipad
how to sync ypur iphone4 with your computer
ipad not showing photos after sync from pc
ipad will not sync photos with pc
my ipad photos do not sync in folders as on my pc
pc pictures not showing pictures on ipad in itunes
sync photos from pc to ipad
sync photos pc ipad
why can i no longer sync photos from my iphone
why can i not sync photos to my ipad
