White Icon
This is a discussion on White Icon within the iPad Help forums, part of the Apple iPad Discussions category; I've just update my Pdfnotes program, but its icon in the "open in" menu (from all other programs) become white as well as its icon ...
White Icon
I've just update my Pdfnotes program, but its icon in the "open in" menu (from all other programs) become white as well as its icon in "Settings". The icon on the homescreen's fine, though. I just want to know what's causing it. I'm using a 64GB 3G/Wifi iOS 4.3.5 without any jailbreak.
10-10-2011 11:48 PM
It might be worth deleting the app entirely and then reloading it. You won't have to pay again; the iTunes store keeps a note of all your purchases and, at the final stage as you go through the purchase process iTunes will tell you 'Already purchased'.
This should fix the problem.
Thanks a lot.
Yep. By reinstalling it, the problem's solved, but all the data in the program will be completely lost. I've updated the app 2 times and have to reinstall it twice after each update. It's not a big deal really, but I am just curious about the cause of the problem. The ipad is brand new and without any jailbreak.
Thank you so much for the advice. I've already tried restart, and close the app for several time, but nothing change. It's like the only way to solve the problem is to reinstall it. I've asked my friends to update the app and no one has the same problem.
What a pity! I switched to Apple because it rarely has bug. Anyway, thanks again for the advice.
- You may not post replies
- You may not edit your posts
Forum Rules
By Cincybearcatfan in forum iPad Hacking
Last Post: 08-05-2011, 04:25 PM
By Pichon617 in forum iPad Hacking
Last Post: 07-05-2011, 09:41 AM
By droid2mac in forum iPad 2 Forum
Last Post: 04-05-2011, 08:50 PM
By krause28 in forum iPad 2 Forum
Last Post: 04-03-2011, 10:34 AM
By Farnomn in forum iPad Hacking
Last Post: 05-18-2010, 09:42 PM
icon become white
ipad 2 settings icon blank
ipad contacts icon blank
ipad icon become white
ipad settings icon white
ipad settings logo white
ipad video icon white
my settings icon is white
setting icon become white
setting on ipad become white
white contacts icon ipad
why are my ipad icons white
