Mp4 movie no audio
This is a discussion on Mp4 movie no audio within the iPad Help forums, part of the Apple iPad Discussions category; Synched an mp4 movie, tried to view it in ipad via "videos" . No audio. Checked it in my computer it was ok. Help?...
Results 1 to 5 of 5
    82735
    Jul 2011
    italy
    41
    Mp4 movie no audio
    Be inspired, be very inspired!
    116 times
    15,249
    82735
    Jul 2011
    italy
    41
    Thanks! Tried the steps, still didnt work. I then noted that the codec in the file description reads "H264" instead of "MPEG 4 video" as in the rest. Could this have something to do with it?
    iPad Addict
    27034
    5 times
    Dec 2010
    Gettysburg, Pa
    1,237
    Try installing Oplayer from app store....free video player that supports different audio codecs...
    82735
    Jul 2011
    italy
    41
    Still didnt work. I tried "movie player" as well - another app that plays multi formats. The strange thing is, it plays ok on my computer?Thanks for help anywys
  1. No audio!!
    By oldfool33 in forum iPad Help
    Last Post: 07-25-2011, 03:58 AM
  2. iPad headphone audio v dock audio; is there a difference?
    By Pagliacci in forum iPad General Discussions
    Last Post: 04-09-2011, 09:26 AM
  3. Will Skyfire stream audio from flash audio player?
    By wahoowad in forum iPad General Discussions
    Last Post: 04-03-2011, 03:54 PM
  4. rented movie, synced ipad, cant find movie??
    By fergs in forum iPad Help
    Last Post: 09-14-2010, 12:05 AM
ipad movie no sound
ipad movies no sound
ipad mp4 no sound
ipad mp4 video no sound
iphone mp4 no sound
movie player ipad no sound
mp4 no sound ipad
mp4 no sound on iphone
mp4 video no sound ipad
no sound mp4 ipad
no sound mp4 iphone
no sound on mp4 video ipad
