Dear all,
Whenever i m surfing my safari, the ipdad2 will rerurn to home screen and i have to unlock my ipad2 and then continue with my safari.
Anyone can assit me as to what reset can i do please?
Thks.
This is a discussion on Return to home screen whe surfing safari within the iPad Help forums, part of the Apple iPad Discussions category; Dear all, Whenever i m surfing my safari, the ipdad2 will rerurn to home screen and i have to unlock my ipad2 and then continue ...
Dear all,
Thks.
OK - no problem. Let's try the simple things first..
No problem - hope you stick around and we hear from you again soon.
Did the power shut down and a few mins later did the power up n the problem is gone now,many thaks Tim.
