Results 1 to 4 of 4
    106030
    Oct 2011
    Cordoba Province - Spain
    32
    Red face iPad2 - Charging in car
    I am expecting delivery of a iPad 2 wifi+3g early next week.
    What amount of power is needed to charge using iPod input to the music system?
    I own a Powergorilla power pack system (with mains and solar charging), with a usb output, so I should be able to use this, if the Volvo idea does not work.
    116 times
    15,249
    The iPad normally takes 2.1 A to charge at the fastest rate. But, of course, it will charge at lower currents, but will take longer. When the current is quite low the iPad displays 'Not charging' to alert you to this fact though it is, in reality, charging slowly (if the iPad is switched off).
    106030
    Oct 2011
    32
    Hi again
    I have found the answer on the Powergorilla website. They sell an iPad adaptor which I have ordered. They state that the USB adapter on the Powergorilla should not be used as it does not put out the 2.1 required by iPads. Using Powergorilla, is set to 8.4 volts, (it adjustable), charging takes 2.5 hours. iPads can also be charged using there solar panel. So a handy accessory, I used mine to run a netbook in a no electricity area in Costa Rica last January using the solar pack.
    116 times
    15,249
    Thanks for letting us know. Good to hear that you're able to use your iPad successfully!!
  1. iPad2 charging in Germany
    By hgeorge164 in forum iPad 2 Forum
    Last Post: 02-11-2012, 08:09 AM
  2. iPad2 not charging through via PC USB
    By bat0nas in forum iPad Help
    Last Post: 06-22-2011, 04:53 AM
  3. Replies: 19
    Last Post: 06-15-2011, 09:01 PM
  4. ipad2 not charging??
    By gypsy_rhythm in forum iPad Help
    Last Post: 05-14-2011, 01:06 PM
  5. Ipad2 charging
    By Zitdoc2 in forum iPad 2 Forum
    Last Post: 04-23-2011, 12:25 AM
charging ipad 2 in car
charging ipad2 in the car
charging requirements ipad 2
ipad 2 charging requirements
ipad 2 not charging car
ipad 2 not charging in car
ipad 2 not charging when connected to car
ipad 2 will not charge in car
ipad not charging in car
ipad powergorilla not charging
ipad2 charging requirements
ipad2 not charging in car
