There's sound from the speakers when I play Itunes music but when Iconnect my earphones to the Ipad there's no audio. How does one correct this?
This is a discussion on Headphones don't work on Itunes. within the iPad Help forums, part of the Apple iPad Discussions category; There's sound from the speakers when I play Itunes music but when Iconnect my earphones to the Ipad there's no audio. How does one correct ...
Make sure the headset jack is firmly seated.
Also, the speaker and headphone volumes are seperate. If you have not done so try turning up the volume while the headphones are plugged in.
If none of that works give a restart a try. You never know what that will fix.
Restart: Hold down the power button until the power off slider appears. Slide it off. When the iPad finishes shutting down, hold down the power button again until the Apple logo appears.*
Thanks for the reply, I have yet to try your suggestions but I thought I'd mention an information that I neglected to say in the original post. That info is that the earphones work OK when I'm listening to audio from other applications such as YouTube, or Skype, etc. Also I have tried the first two suggestions of making sure the plug is well seated in the jack, and the volume is up. Is this of any help in diagnosing the problem?
Strange. Check your iPod settings in the Settings app and see if you've turned on the volume limiter. It's the only thing I can think of that would do that.
I think I have found the cause of my problem. It must be a defective earphone jack on my Ipad. Now I cannot hear any audio through the earphones with any application --- YouTube, or streaming radio prorams, or.anything yet when I remove the earphone plug, audio comes out of the built-in speakers. I even tried a different headset with the same results. Bad connections?
Could be. If it is and your iPad is less than a year old Apple will replace (or fix) it under warrantee. Might want to give them a call.
Yes, it must be a defective connection in the jack because I just tried Skype again and there was audio! Also tried an email with a video clip in it and there was perfect audio also! And I can hear the "click" when I type the words on this email! This intermittent loss of earphone audio has got to be due to bad connections in the jack.
