iPad wifi not connecting through access point but connects thru router
This is a discussion on iPad wifi not connecting through access point but connects thru router within the iPad Help forums, part of the Apple iPad Discussions category; Hi everyone. Regards to everyone. My first post here I bought my new ipad2 today. I am facing a problem with the wifi. I initially ...
Results 1 to 7 of 7
    104383
    Sep 2011
    India
    Hi everyone.
    I bought my new ipad2 today. I am facing a problem with the wifi. I initially connected the iPad in my office on the upper flower where Internet is through wifi router and the Internet worked perfect. But on my lower floor I have an access point installed to get better signal strength. My android phones wifi , my laptops wifi etc work nicely through this access point and get nice signal strength but when I took my iPad on the lower floor it is not workingthrough the access point . The Internet just stops. When I saw in the dhcp settings of iPad wifi I can see it's not able to get right ip address and also not able to retrieve the router address. When I turn off the access points the Internet works again withthe direct signal from the main upper floor router even if the signal strength is low. What shula I do to use the wifi through the access point? I never faced this problem with my android phone or a windows laptop. They configure on their own and I can use Internet both through router directly and access point also. Plz help. I need to use wifi through the access point on the lower floor
    104383
    Sep 2011
    India
    No replies?????
    Plz help
    577 times
    Dayton, WA
    13,181
    All routers and access points work a bit differently, and they are a pain to troubleshoot remotely. That goes double for a network with access points. Most of us who read this are probably waiting in hope that someone who has the same equipment will come along and give you a real answer.
    As for myself, I simply haven't a clue. The only access points I've ever set up were all Apple gear, and I just fiddled until they worked.
    Your best bet is to contact the manufacturers and see if they have any answers. It might happen.
    One random thought. Make absolutely sure the access point is not acting as a DHCP server. Only the primary router should do that.
    104383
    Sep 2011
    India
    My access point is set to static ip and not dhcp. All my other devices are working fine through this AP. Just this damn iPad doesn't. I read somewhere regarding making separate networks for separate bands but I haven't understood it. I am not able to post the link here as my post count is low
    104383
    Sep 2011
    India
    My access point is set to static ip and not dhcp. All my other devices are working fine through this AP. Just this damn iPad doesn't. I read somewhere regarding making separate networks for separate bands but I haven't understood it. Just see if u do.
    http://www.mydigitallife.info/how-to...int-problem-2/
    577 times
    Dayton, WA
    13,181
    The article isn't exactly for your problem, and given their brief instructions I'm not completely sure what they are doing. They are either placing the WPA on a separate channel, and giving it a new name SSID, or creating another network in parallel. I'm not sure you can do the first, it would probably depend on the router. The second would require either a hardwire ethernet port connected between the two, or use of dual band routers.
    As I said, I just don't know enough to help.
    I'm not sure what you mean by your WAP being a static IP. It should't handle IP addressing at all. As a part of the network all IP's should be distributed by the main router. Anyway, the fact that your other devices work probably means it's ok.
    You could try setting up your iPad as a Static IP. Your router should be able to assign a static IP to a specific MAC address. You can see this in the Genreal > About settings on the iPad. Once you have assigned the IP in the router, go to the Network settings on you iPad, choose the network, change it to Static, and assign the IP to the iPad. You'll want to take note of the other entries, like DNS and router, on the iPad before doing this. Use the ones on the main router that work. Enter those as well as the static IP in the iPad's network settings (for that network).
    I don't know if this will work, but it's worth a try.
    265638
    Dec 2012
    cairo
    i had the same exact problem for sometime. my ipad2 wouldn't connect to an access point but connects to the router feeding the access point. here is what i did and it worked for me.
    under the Wifi tab, while making sure your access point Network name is showing after searching for Wifi signals, click on other, then type in your network name of the access point. in my case there was no security so i left it as none. if after inputing your password it still did not work, try to disable your security and try again.
    hope this helps.
  1. iPad2 as WiFi access point
    By fre_ber in forum iPad General Discussions
    Last Post: 12-05-2011, 08:41 PM
  2. Connecting to internet via SMC router on iPad?
    By FromThailand in forum iPad Carriers
    Last Post: 07-07-2011, 03:11 AM
  3. 4.2 wifi no longer auto connects
    By lanimae in forum iPad OS
    Last Post: 02-07-2011, 08:22 AM
  4. Replies: 2
    Last Post: 01-16-2011, 12:33 PM
  5. Replies: 1
    Last Post: 12-06-2010, 07:06 AM
conectar ipad em access point
connect ipad to access point
connecting an ipad to a wireless access point
ipad access point selection
ipad connect to ap
ipad having issues connecting to access point
ipad nao conecta em um access point
ipad not connecting ap
ipad not connecting to access point
ipad wireless access point
ipad wont connect to access point
point access number for ipad
