Transferring photos imported to ipad to my computer after using Camera Connection Kit
This is a discussion on Transferring photos imported to ipad to my computer after using Camera Connection Kit within the iPad Help forums, part of the Apple iPad Discussions category; As a typical nooby this question may be easy for some to answer. I went out and purchased the Camera Connection Kit which I was ...
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By gfkw47
  • 1 Post By twerppoet
Thread: Transferring photos imported to ipad to my computer after using Camera Connection Kit
    37654
    Chatham
    As a typical nooby this question may be easy for some to answer. I went out and purchased the Camera Connection Kit which I was able to transfer my photos from the camera using the SD card. The connection was simple plug the Camera Connection SD adapter in to the IPAD and insert the SD card. Simple application and the photo files were loaded on my IPAD. It will ask you to delete these photos off the SD card which I did with no troubles transferring the photos into an albums on my IPAD called "All Imported". When I plugged the IPAD into itunes I thought this album would sync an appear in my photos section but it did not. I am hoping that something simple that I have not done can easily be resolved. Hoping to hear what that simple fix is.
    116 times
    15,249
    I've moved this to the Help section, where I think it will receive better attention.
    580 times
    Dayton, WA
    13,192
    If you are using Windows, the iPad should show up on the PC as a USB drive. Both the pictures on the Camera Roll and Imported pictures should show up under the DMIC folder.
    83738
    Aug 2011
    Norfolk, England
    6
    Quote Originally Posted by Liberty
    Hi - did you ever get an answer to this. My problem is very similar. I took lots bog photos with camera on holiday and downloaded onto IPad, and also a few using the IPad. I now want to transfer to PC to organise them into files (don't think it can be done on the pad). When I try to sync I get a message asking if I want to replace the synced photos on the IPad. It says the IPad contains photos synced with another folder and they will be replaced. Not sure how Ingot to here but I am very scared of losing all my photos. Anyone got any thoughts please?
    Dubuff likes this.
    580 times
    Dayton, WA
    13,192
    When your iPad is connected to your Windows PC, it should show up as a USB drive under MyComputer. Your imported pictures will be in the DMIC folder in a subfolder named something similar to 105IMPRT.
    The sync warning you are describing only applies to photos synced through iTunes from a folder on a computer. It does not affect the camera roll or imported photos. Check your photo sync settings to see what folder(s) you have set up to sync.
    iPhone, iPad and iPod touch: Syncing photos via iTunes
    Dubuff likes this.
    83738
    Aug 2011
    Norfolk, England
    6
    Got it thanks. Thanks for your help.
    580 times
    Dayton, WA
    13,192
    No problem.
    193137
    Apr 2012
    I am trying to upload photos and the iPad I saying it requires too much power. I have 94 charge and of course cannot plug in at the same time. Really a nooby here
  1. Digital camera video imported to my iPad 1
    By CMFox in forum iPad Help
    Last Post: 09-09-2011, 09:26 PM
  2. Transferring photos from camera to ipad
    By intownred in forum iPad General Discussions
    Last Post: 07-13-2011, 12:53 AM
  3. Organizing imported photos - Saved Photos
    By rmsturm in forum iPad Help
    Last Post: 05-23-2011, 04:28 PM
  4. Photos, Albums and iPad Camera Connection Kit
    By Melburstein in forum iPad Help
    Last Post: 11-27-2010, 03:45 PM
  5. Camera Connection and assigning photos to album
    By Dino in forum iPad General Discussions
    Last Post: 11-21-2010, 12:36 PM
cannot see dmic pictures from my iphone 5 in my computer
how can i transfer pictures from my iphone 5 to my ipad
how do i get my pictures from my ipad to my windows vista
how do i get my pictures from myh ipad to the computer
how to transfer photo albums from ipad to pc
how to transfer photos from ipad to computer using window 8
importing photos from ipad to computer
this ipad contains photos synced with another photo library or folder
tranfrer photos via connection kit to another ipad
transfer imported photos from ipad to computer
who to transfer the imported photo in new ipad to pc
