Popup Screen: Could Not Activate Cellular Data Network
This is a discussion on Popup Screen: Could Not Activate Cellular Data Network within the iPad Help forums, part of the Apple iPad Discussions category; How do I turn the Cellular Data popup off? I don't subscribe to Verizon (iPad Designation), so don't appreciate the frequent notification that my iPad ...
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 46
    102837
    Sep 2011
    36
    How do I turn the Cellular Data popup off? I don't subscribe to Verizon (iPad Designation), so don't appreciate the frequent notification that my iPad 2 can't make the connection. My "Settings/Cellular Data" is already set to Off. The goal, by having it set to off, is to prevent the IPad from using this function all the time. Anything to lessen the draw on the battery. Obviously this didn't work, so is there another way to stop the popup screen?
    116 times
    15,249
    I moved this to the Help section, where I think it will receive better attention.
    102837
    Sep 2011
    36
    Thanks Tim. As you can see I'm new to this setup.
    BTW like your alien six-shooter!
    116 times
    15,249
    Are you actually getting a cellular data can't connect pop-up or simply one that says the iPad can't connect to the Internet?
    My avatar is not of my own making - it was put there by one of the other Moderators, SweetPoisin.
    102837
    Sep 2011
    36
    Nope getting exactly as I wrote it.
    102837
    Sep 2011
    36
    That's funny, your peers are looking out after you. Did you return the favor? I got a kick out of it.
    116 times
    15,249
    OK - but something on your iPad must want access to the Internet - perhaps it's your Mail app trying to check for new email? Presumably you're in an app that doesn't require Internet access - perhaps an Office app - and you're getting this pop-up as, say, Mail checks for new email. Have you got your Mail app set to automatically retrieve email?
    102837
    Sep 2011
    36
    I'm familiar with the screen prompt when my system can't connect with the internet. This isn't that. I do have my system setup to check e-mail every 15, but that shouldn't involve my cell function, because I have that function totally shut down. There is a special area to shut that off, in the settings area.
    116 times
    15,249
    OK - so you're saying that you're connected to WiFi (so that your Mail client can check for email) but that this pop-up still occurs - even though you're connected to the Internet via WiFii? That is very strange because, as I'm sure you know, the iPad will absolutely always try to use WiFi to connect to the Internet irrespective of how poor that connection is - i.e. it will never switch to 3G if there's a WiFi connection available.
    As you say, too, there is a special area in the 'Settings' menu ('Cellular Data'), where you can turn off access to cellular data for precisely the reason that you cite.
    I'm hoping that another Member will come along with some other ideas because, as you can see, I'm running out of ideas myself....
    102837
    Sep 2011
    36
    Yes, everything you've said is correct. I am connected to the Web, often typing an e-mail or Web searching, and that darned popup screen will appear. And of course it insists that I click it off before I can continue typing. I know the iPad always searches for a WiFi connection and only goes to 3G, if it can't find the former,
    Thanks for giving the issue some though, even if you couldn't figure it out. It drives me nuts, as you can imagine.
  1. "Could not activate cellular data network"
    By shark55 in forum iPad General Discussions
    Last Post: 08-15-2011, 11:23 AM
  2. Activate Verizon data plan without wifi
    By forkyfork in forum iPad 2 Forum
    Last Post: 07-03-2011, 06:07 AM
  3. Could not connect to cellular data network
    By Dj13e in forum iPad General Discussions
    Last Post: 05-14-2011, 03:54 PM
  4. Cellular Network Data - measures data use since...?
    By MLimtiaco in forum iPad General Discussions
    Last Post: 06-30-2010, 09:21 PM
  5. 3g and "Could not activate cellular data network"
    By Rfields987 in forum iPad General Discussions
    Last Post: 06-25-2010, 03:14 PM
can't activate cellular data network
could not activate cellular data network ipad
could not activate cellular data network pop up how to disable in iphone
disable could not activate cellular data network
how do i turn off cellular data alerts on my ipad
how to turn off cellular data notification on ipad
ipad can't connect to cellular network
ipad could not activate cellular data network verizon
ipad says could not activate cellular data network
notification about celluar data on the ipad
turn off cellular data alert on ipad 2
verizon ipad could not activate cellular data network
