Keep Losing WiFi
This is a discussion on Keep Losing WiFi within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I'm still new at the iPad thing. But my iPad keeps losing wifi connection. I have to turn off wifi in settings and then ...
Results 1 to 5 of 5
    94051
    Aug 2011
    UK
    5
    Keep Losing WiFi
    Hi, I'm still new at the iPad thing. But my iPad keeps losing wifi connection. I have to turn off wifi in settings and then turn it back on. This is really frustrating especially when doing stuff like THIS. I have had to type this twice. Just wondered if anyone could help me out with this problem. THANKS.
    98944
    Sep 2011
    Whitestone, NY
    62
    I would make sure its not a problem with the wifi source itself first. If it isnt, I would try backing up and restoring the iPad to factory settings. If THAT doesnt work, I would make an appointment at the apple genius bar and have it looked at and possibly replaced.
    iPF Super Guru
    40746
    99 times
    NW Left Coast
    3,504
    Quote Originally Posted by Sexybum13 View Post
    Although you should make sure your network is functioning properly, you shouldn't have to restore your iPad.
    The most recommended "fix" for this issue is to go into your WiFi settings, tap on the network you're using (small arrow inside the little blue circle next to the network name) and tap "Forget this Network". Restart your iPad by holding down the power switch (outside edge) until the red power off slider appears, shut it down and then hold down the power switch again until the Apple logo appears. Once booted up go back into the WiFi settings and set up the network again.
    More here:
    iOS: Troubleshooting Wi-Fi networks and connections
    Hope that helps and let us know how it goes!
    53991
    2 times
    May 2011
    Maryland
    180
    I had the same problem with my iPad 2 and my iPhone. Turned out to be my router in my case. Apple Airport Extreme. Apple replaced it and have not had the problem since. I would check everything related to your home network to include the router, modem and any switches (if you have any).
    iPF Super Guru
    40746
    99 times
    NW Left Coast
    3,504
    Rebooting the network can often help as well...including the modem/router, etc.
  1. Losing WiFi
    By Sexybum13 in forum iPad Help
    Last Post: 10-01-2012, 01:31 AM
  2. Losing wifi intermittently
    By LesleyB in forum iPad Help
    Last Post: 06-23-2012, 01:57 AM
  3. ipad 2 wifi only losing connection
    By accordlayingkit in forum iPad 2 Forum
    Last Post: 05-24-2011, 09:05 PM
  4. Losing Wifi connection
    By DeniseS in forum iPad Help
    Last Post: 05-19-2011, 01:54 AM
  5. Keep losing wifi connection
    By Dpeach in forum iPad Carriers
    Last Post: 06-29-2010, 06:28 AM
ipad 2 keeps losing wifi connection
ipad keeps losing wifi
my ipad 2 keeps losing wifi
my wifi on ipad keeps going in and out
why do i keep losing my wi fi connection to my ipad air?
why does ipad lose wifi connection
why does my ipad keep losing wifi
why does my ipad keep losing wifi connection
