Losing WiFi
This is a discussion on Losing WiFi within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I'm still pretty new to iPad. I keep losing my home wifi connection and the only thing I have found that I can do ...
Results 1 to 3 of 3
Thread: Losing WiFi
    94051
    Aug 2011
    UK
    5
    Losing WiFi
    Hi, I'm still pretty new to iPad. I keep losing my home wifi connection and the only thing I have found that I can do to get me back on is by turning off wifi in settings and then turning it back on. Was just wondering if anybody knows how I might keep my wifi switched on..
    116 times
    15,249
    Some Members have found that, when this happens, one way forward is to go into the WiFi area in 'Settings' and to tell the iPad to forget all its connections and then to re-establish them all again.
    248088
    Oct 2012
    Quote Originally Posted by Sexybum13 View Post
    I know how to fix this issue
    Go to setting/general/reset
    Then hit reset network setting
    After that go to
    Settings/wifi
    Dont select your network
    Hit other then manually type in your ssid
    After that select your encryption
    Then push back enter your password and your should be good to go
  1. Losing wifi intermittently
    By LesleyB in forum iPad Help
    Last Post: 06-23-2012, 01:57 AM
  2. Calendar losing data
    By Blloydqld in forum iPad Help
    Last Post: 09-15-2011, 05:49 AM
  3. ipad 2 wifi only losing connection
    By accordlayingkit in forum iPad 2 Forum
    Last Post: 05-24-2011, 09:05 PM
  4. Losing Wifi connection
    By DeniseS in forum iPad Help
    Last Post: 05-19-2011, 01:54 AM
  5. Keep losing wifi connection
    By Dpeach in forum iPad Carriers
    Last Post: 06-29-2010, 06:28 AM
ipad keeps dropping wifi
ipad keeps losing wifi
ipad keeps losing wifi .
ipad keeps losing wifi password
iphone 5 losing wifi
iphone keeps losing wifi
iphone losing wifi password
iphone5 looses wifi connection
iphone5 loses wifi connection
iphone5 wifi keep dropping connection
new ipad loosing wifi connection
why is iphone 5 loosing the wifi
