Sound volume randomly goes to max
This is a discussion on Sound volume randomly goes to max within the iPad Help forums, part of the Apple iPad Discussions category; Since a week or two, i have the sound volume going to the max over and over again, randomly. The little screen in the middle ...
Results 1 to 10 of 13
    99606
    Sep 2011
    8
    Unhappy Sound volume randomly goes to max
    Since a week or two, i have the sound volume going to the max over and over again, randomly. The little screen in the middle pops op and the volume bar runs up from left to right. The only way to get rid of this little screen is to lower the volume with the button on the side of the ipad. The sound switch is in the off position. Switching itnhas no effect. I dont care for sound much, i use the ipad for my work and to read internet and or books. Lately i am pressing the volume button a lot just the get rid of the volume screen.
    I have reset the ipad, by pressing the buttons 10 seconds as described in the manual. I used the reset function via itunes. All that has not fixed this pronlem. Last resort is to go back to factory setting, did not work, last chance looks like emptying it and not setting back the backup. Changes in the setting, like switching off search for wifi, pushmessages etc, did not help as well.
    Anyone a suggestions for me how to fix this?
    Appreciating any help i can get.
    81236
    Jul 2011
    71
    Wow! Sounds like you've already done a ton of troubleshooting. I don't have any other ideas and if no one else pops in with any, my next suggestion would be to call Apple!
    Mistress of Mischief
    99606
    Sep 2011
    8
    i gues i will have to resort to that Missy.
    48854
    77 times
    Weston WI
    856
    Have you checked all your settings? The mute switch can be changed to screen position lock.
    You can also double click the home button and swipe the lower row to the right until you see the sound bar. Just tap the home button to get the lower row to slide away. This bar is also where you turn off apps.
    20755
    7 times
    Nov 2010
    Michigan
    436
    Starting to sound like a hardware problem. Either a funky volume switch, or internal trouble. I haven't heard of the volume running up by its self anywhere else. You might be in for a trip to the apple store for a possible replacement.
    99606
    Sep 2011
    8
    Quote Originally Posted by Czevski
    Thanks for the advise, i will check these option out. If it solves the problem i will let you know.
    99606
    Sep 2011
    8
    Quote Originally Posted by Jeeper
    Hi jeeper, it seems to look that way. Strange, the ipad has not been used abnormally, no throwing it arround or any other disasterous thing happened. I will check out some other option i just got in here. If ist works, i will report it here, if not, that i have to get it back to the store.
    26595
    Dec 2010
    GA
    The same thing is happening to me except that it is the volume going all the way DOWN for me. Same situation though. Box pops up and volume slider goes all the way down but then box stays in the middle of my screen until I touch the volume rocker to turn it up manually. Of course within 5 min it happens again. Ive done a reset and a restore as well. Just curious if you found an answer or ended up going to the apple store?
    99606
    Sep 2011
    8
    Quote Originally Posted by gadawg94
    No answer jet. Thanks for your note, now i dont feel alone anymore. Sorry! No solution jet. Many i speak about this tel me it looks like hardware failure.
    I want to do one more test myself. I will bring my ipad back to the factory settings and take all apps and files offnthat did not come with the ipad. Than it should be like new. If the problem ocures again, than its definately an ipad problem, to be solved by apple. I will return mine to the shop for repair or replaced. I have not a jailbrake on it, so all i have done with it sofar is on the up and up applewise.
    I appreciate it if you find an onther solution, if you let me know in this forum. I will do the same until its fixed either way. Our problem seems to be the same problem.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Definitely sounds like a hardware issue. I had exactly the same thing on my iPhone4 and it was a short in the hardware. Apple store replaced it immediately. There is nothing I know of in the software that can cause this sort of problem. I suggest you take it into a store and explain the problem. They will likely replace it on the spot.
  1. How to increase sound volume?
    By taffy in forum iPad Help
    Last Post: 07-18-2011, 12:15 PM
  2. Applications Closing Randomly
    By daveyd90 in forum iPad Help
    Last Post: 03-21-2011, 03:00 AM
  3. Replies: 19
    Last Post: 03-14-2011, 10:16 PM
  4. Losing sound randomly....
    By Dream in forum iPad Help
    Last Post: 12-24-2010, 05:24 PM
  5. Sound volume control
    By TFarmer in forum iPad General Discussions
    Last Post: 10-07-2010, 05:10 PM
ipad 2 no volume bar anywhere hiw to fix?
ipad volume changes by itself
ipad volume goes up by itself
ipad volume keeps going up
ipad volume randomly changes
ipad volume turns up by itself
ipod randomly turns volume up
ipod volume goes up by itself
volume changing randomly in ipad 2
volume goes up by itself ipad
volume goes up on ipad
why ipad volume keep increase to max
Tags for this Thread
