Need help syncing multiple iDevices on same laptop (PC)
This is a discussion on Need help syncing multiple iDevices on same laptop (PC) within the iPad Help forums, part of the Apple iPad Discussions category; I have three different iOS devices under the same iTunes account and I'd like to be able to sync them and avoid messing things up. ...
Results 1 to 2 of 2
    79022
    Jul 2011
    South Florida
    5
    My concern comes from my earlier experience in syncing my wife's iPhone and my daughter's iPod Touch. Although they both use the same iTunes account, I wanted to be able to choose which apps go to which device. Instead, both devices got all apps synced and now they both had to (well, I did, actually. Yeay for in-home tech support ) delete each other's apps from their devices.
    Now we have a third device, an iPad 2. First off, let me say that I should have gotten the 32GB model and the $100 savings was not at all worth it. I've got tons of apps (and few pics, videos and songs) and need to constantly delete apps.
    With that out of the way (sorry about that!), I have never synced the iPad, fearing that all my (mostly) iPad apps would not only be synced to the other devices but, worse, those other devices' apps would sync INTO my iPad -which would probably not happen, as all I have is about 200MB free.
    So, onto my questions:
    - how can I avoid having those other apps synced to my iPad? I've got the iPad hooked up now and although iTunes shows (as far as I can tell) only the iPad's app, I'm a bit hesitant in syncing it and having those other apps synced in.
    - speaking of iTunes, why is that, under the "Apps" tab, none of my app folders (created on the iPad) are shown on iTunes. Thanks to folders, all I have are 4 pages of apps, whereas iTunes shows 11. Yet, on iTunes, I can drag two apps together and create a folder -what gives?
    - what's the best way to manage syncing? I currently have it set to NOT sync automatically when connected and to only sync checked items (songs/videos, etc).
    Any help/tips are appreciated!
    //edit:
    The fsck? Without syncing (or changing anything), iTunes' capacity meter, at the bottom of the screen, just changed from showing 200MB free to 1GB OVER capacity.
    iPF Super Guru
    40746
    99 times
    NW Left Coast
    3,504
    Quote Originally Posted by Carioca_FL View Post
    //edit:
    You can easily manage multiple iOS devices on the same Apple ID on the same computer in iTunes.
    When you first connect any one of them iTunes will open and a backup will be created. After that all you need to do is click on your device in the left-hand column and then click on the Apps section at the top. Check or uncheck the box next to the apps you want or don't want to sync with your device. Click on "Apply" at the bottom and the device will re-sync with only the apps you've checked. If later you find an app you don't want on your device simple tap and hold its icon until it starts jiggling. Press the "X" in the upper left-hand corner, confirm that you want to delete it and that's it. If you're missing an app you want reconnect it, check the box next to the app name and click on "Apply" (or if you're away from your computer you can download it from the iTunes Store again.
    Once you fully sync your iPad all of the folders you've created on your iPad should be reflected on the iTunes Apps section as shown below and the capacity should be normal.
    Hope that helps!
  1. Replies: 6
    Last Post: 08-25-2012, 09:38 AM
  2. Syncing multiple ipads
    By BigMAC in forum iPad General Discussions
    Last Post: 09-16-2011, 10:16 AM
  3. Syncing ipad to laptop
    By Yukongal in forum iPad Help
    Last Post: 08-13-2011, 03:16 PM
  4. Same game on multiple idevices?
    By uniquename in forum iPad Games
    Last Post: 06-12-2011, 11:37 PM
  5. Syncing devices to multiple iTunes accounts on multiple computers.
    By Philippe in forum iPad General Discussions
    Last Post: 11-27-2010, 04:55 AM
apple forum how to syc multiple devises
can i sync multiple apple devices to one laptop
can i sync multiple iphone to the same laptop
can you sync two iphones to one laptop
can you use one laptop to sync two different iphones
how do i sync multiple iphones on one laptop
idevices download for laptop
laptop of multiple iphone
pages on ipad sync to all ipads
