[Help] iPad doesn't restore
This is a discussion on [Help] iPad doesn't restore within the iPad Help forums, part of the Apple iPad Discussions category; I really need help, i screw up my friend's iPad. He gave it to me, just for Jailbreak it and put some App's and Games. ...
Results 1 to 4 of 4
    6115
    Jun 2010
    12
    Well, i spirited, normally, everythings was fine, but when i opened Cydia for the fist time, iPad reboot by self, and when he loaded the OS, all natives App dissapeared (Photos, Safari, Notes, Calendars, Contacts, Youtube...) Least Settings.
    I guess, something were wrong, so i decided to DFU and restore it
    I download the Firmware 3.2 for iPad from iTunes, and, when it start to Restore, i wait 2hours and the Apple's load Bar doesn't move, from iTunes, and even on iPad.
    PS: Sorry for the Low resolution camera (iPhone 3G, rsrsrs)
    PS˛: I'm Portuguese, on the iTunes, it says: "Restoring iPad's Software"
    Please i'm begging for Help, i spend hours and hours on google trying to find an answer, but didn't appers to be a common problem, i think this is only with me.
    Attached Thumbnails Attached Thumbnails [Help] iPad doesn't restore-img_0153.jpg   [Help] iPad doesn't restore-img_0152.jpg
  2. #2
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    Reboot the ipad by holding both the power and home buttons. What does it do? does it give the message saying it must be connected to iTunes?
    Do you keep getting stuck in a loop where the restore does that and then you reboot and get the same Connect to iTunes but iTunes says it must perform a restore?
    If That is the case, Connect the iPad to the computer while its showing the connect to iTunes logo and run the spirit jailbreak. It should Reboot the iPad and and start working like normal.
    Also just a tip, If your freind cant jailbreak the ipad on his own I would say he shouldnt be using a jailbroken iPad. Most of the jailbroken apps will break the ipad and stop it from working properly. Dont install things from cydia unless you know for sure its been tested to work on the iPad.
  3. #3
    6115
    Jun 2010
    12
    Quote Originally Posted by MikesTooLz View Post
    Yeah, i already did this, when i press Only the power button, it show a to Connect to iTunes
    No, it stucked in the restore, i already tried 3 times, and always stuck in the same part. And when i connect to iTunes, it does say to Perform a Restore.
    It stuck on the progress bar to restore, like the in the images i uploaded.
    I did what i did, because i have a iPad too, when i did my Jailbreak, nothing went wrong, i'm a iPhone user too, since a long time, and i know what Cydia App's i can install, and can't
    EDITED:_______
    Well, i try to do that, but when i start Spirit, i cannot click on the "Jailbreak" button.
    PS: i Did that, with the iPad turned on, showing the Cable to Plug onto iTunes
    EDITED˛:________
    I FOUND A SOLUTION!
    Something was wrong with my computer. I install iTunes on my Brother's PC and restore my friend's iPad normaly, everything went OK!
    Thanks GOD
  4. #4
    27363
    i just want to say this thread helped me a bunch! i had installed a Cydia app to allow easy asses to the filesystem via usb and windows and after installing it had the reboot button which what i should have done was done the teathered boot (as i have the 4.2 tethered jailbreak at the moment) but install it let it reboot itself and apparently it caused it to hang. tried to restore but it did nothing but got stuck still on the apple white logo. I really started to panic as i had JUST bought the ipad a few days ago online and had a lot of bad misfoturine over the past few years and figured oh great here we go i just got this great new device which allows me to share pictures and all and i go and cause it to freeze.....i was so upset! but i tried to remain calm and looked up online and found this forum. i have the redsn0w installer but after connecting i thought hmm maybe if this alternate mode to enter DFU (i used a simpler way when connecting with itunes) anyways i followed the on screen instructions and it worked i was able to reboot it into the jailbroken mode and it got it unstuck!
    So if anyone has this problem with the stuck apple logo even after "restore" (the restore actually will not work it will appear to be restoring but nothing happens it just goes back to the stuck apple logo mode) try doing a hard DFU mode enter and then use your jailbreak application to reboot it into jailbreak mode. worked for me! awesome! and even better the app extention i was trying to install that cause my ipad to lock up...has now been installed haha :-)
Sponsors
  1. iPad cannot restore
    By dangrousperson in forum iPad Help
    Last Post: 11-06-2011, 09:31 PM
  2. youtube doesn't work in Ipad
    By jacppe in forum iPad General Discussions
    Last Post: 01-23-2011, 10:32 AM
  3. Can't restore iPad
    By winkness in forum iPad Help
    Last Post: 09-24-2010, 02:20 AM
  4. iPad restore
    By Caps in forum iPad General Discussions
    Last Post: 05-02-2010, 09:31 PM
  5. iPad: Unable to update or restore
    By 4phun in forum iPad Help
    Last Post: 04-18-2010, 08:53 PM
how long does a ipad restore take
how long does ipad take to restore
how long does it take to restore a ipad
how long does it take to restore an ipad
how long does it take to restore and ipad
how long does it take to restore ipad
how long it takes to restore ipad
how long should ipad restore take
how long should it take to restore an ipad
how long should it take to restore ipad
how long to reset an ipad
how long to reset ipad
how long to restore ipad software
ipad doesn't restore
ipad restore
ipad restore how long
ipad restore how long does it take
ipad restore loop
itunes is restoring the software on this ipad
restoring ipad software
