Volume Icon Won't Leave Screen
This is a discussion on Volume Icon Won't Leave Screen within the iPad Help forums, part of the Apple iPad Discussions category; Hi, The volume icon won't leave the screen. Now and then it will fade away for a moment only to reappear. I've tried re-starting, checking ...
Results 1 to 7 of 7
    74951
    Jul 2011
    7
    Hi,
    The volume icon won't leave the screen. Now and then it will fade away for a moment only to reappear. I've tried re-starting, checking in settings, and swiping the bottom of the page to bring up the volume control. None of these have any effect on the icon which has decided to plant itself in the middle of my screen.
    Anyone any idea what's going on?
    116 times
    15,249
    Time for a reboot. Turn the iPad off. Now press and hold the Power and Home buttons until the white Apple logo appears - about 6-9 seconds. The iPad will reboot - takes a while. Nothing is lost. See if the problem persists.
    74951
    Jul 2011
    7
    Thanks Tim,
    The problem seems to have gone away after an overnight shut down. It reappeared once briefly and then went again. Nothing since. I'll put it down to some sort of ipad indigestion.
    167299
    Feb 2012
    Australia
    I tried that to no effect. I am having exactly the same problem as the first person
    85546
    477 times
    Aug 2011
    Edmonton AB Canada
    9,528
    Could be a hardware fault. Try operating the volume switch up and down a few times. I'm thinking there might be something sticking inside. Don't take a hammer to it, but tap the switch a bit harder than normal a few times. See if that clears it.
    I'm guessing but I think anything that survives a reboot is not software related. If I'm wrong, which I often am, a backup and restore is probably the next step.
    Sent from my iPad 4 HD mini
    Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
    209335
    May 2012
    i messed around w/ the volume switch down 4x then up 1x down 3x and up 2x
    281132
    Feb 2013
    Florida
    I was having this problem too, and rebooting to correct, then noticed every time it happened was right after I put it back into the iPad holder, upside down! The holder was pressing the power button just the wrong way and causing the problem.
  1. How do I delete an icon from the screen?
    By DM51 in forum iPad FAQ
    Last Post: 07-15-2012, 06:58 PM
  2. Remove icon home screen on the iPad.
    By sauloteles in forum iPad Help
    Last Post: 07-24-2011, 06:06 AM
  3. Deleting a bookmark icon from home screen?
    By basketannie in forum iPad Help
    Last Post: 05-27-2011, 12:32 AM
  4. Screen locked and strange icon
    By Fifialfa in forum iPad Help
    Last Post: 04-27-2011, 04:05 AM
  5. Reset home screen layout, leave dock alone
    By dalesmcd in forum iPad General Discussions
    Last Post: 08-15-2010, 10:35 PM
ipad 2 sound effects icon
ipad sound effects icon
ipad sound icon won't go away
ipad speaker icon
ipad speaker icon won't go away
iphone volume display won't disappear
iphone volume icon won't go away
my volume icon won't go away
sound effects icon on ipad
speaker icon on ipad
volume icon won't go away on iphone
volume sign won't go away
