Ipad wifi only cant locate current position?
This is a discussion on Ipad wifi only cant locate current position? within the iPad Help forums, part of the Apple iPad Discussions category; Hi guys, I am using a wifi only iPad connecting to my iPhone 4. When I am in the city using Maps, it can locate ...
Results 1 to 7 of 7
    71424
    Jun 2011
    8
    Hi guys, I am using a wifi only iPad connecting to my iPhone 4. When I am in the city using Maps, it can locate current position. But when I am at rural area about 40km from the city, it can't locate current position. How come? tx for advise.
    116 times
    15,249
    The WiFi iPad doesn't have GPS. It determines its location using a data base of WiFi hotspots. In the city it can see hotspots and uses their location. In a rural area there are no hotspots and so the iPad is unable to determine its location.
    71424
    Jun 2011
    8
    Really? I thought iPad when connecting to iPhone4 via personal hotspot can use iPhone gps to determine the location. No?
    116 times
    15,249
    I'm not aware of that. Perhaps another Member knows?
    579 times
    Dayton, WA
    13,186
    There were a lot of rumors, tests, and speculation on this for a while, but in the end pretty much everyone either posted a correction or fell silent on the issue. The GPS on the iPhone can not be seen by the iPad when tethered.
    The confusion was caused because with the iPhone tethered the iPad could download the database for local hotspots and triangulate it's rough position. Without the iPhone tethered, and no wi-fi connection of it's own the iPad can only find it's location if it previously downloaded the database for that area. When it was keeping this data forever (and causing a privacy scandal) the odds were good that it had this database if you'd ever been there before with a connection. Now the database is limited to how much it will store, and you are less likely to have it on hand from previous visits.
    And of course, if there are no hotspots in the area, or the ones there are not in the database, you're out of luck even with the iPhone tethered.
    iPad Ninja
    62473
    62 times
    Jun 2011
    1,607
    We've tested this extensively because of an app we developed, and it's never been true. The iPad tethered to an iPhone does not know where it is and never has.
    If the device is not connected to a mapped Hot Spot, then it will not be found.
    If you have an iPhone connected to the same Wifi spot as your iPad, the location WILL end up in the Hotspot database eventually, which is why the false impression that the iPad knows because the iPhone knows comes up regularly.
    The iPhone is NOT a mappable hotspot stored in the central location database.
    -t
    579 times
    Dayton, WA
    13,186
    Thanks for the correction.
    I never thought the iPhone was mappable, I just thought that with an internet connection the iPad could at least download the local database and see where it is that way. Of course, upon further reflection, I should have wondered how it would know what section of the database to download without being connected to at least one of those hotspots?
  1. The iPad screen stuck in fixed position
    By ipad987 in forum iPad General Discussions
    Last Post: 03-03-2012, 11:30 AM
  2. What's your favourite position with iPad?
    By chowdown in forum Apple iPad Polls
    Last Post: 06-02-2011, 04:34 AM
  3. GPS Poor Position Fix
    By TexAus in forum New Member Introductions - Site Assistance
    Last Post: 02-28-2011, 11:38 AM
  4. Charging position
    By Hawkmech in forum iPad General Discussions
    Last Post: 08-22-2010, 06:40 PM
  5. Replies: 3
    Last Post: 06-12-2010, 10:24 PM
cannot determine location ipad 3
current position on ipad
how to fix maps cannot determine location on ipad wifif
ipad 3 cannot determine location
ipad 3 maps cannot determine location
ipad can't find current location
ipad cannot determine current location
ipad cannot determine location
ipad cannot find current location
ipad current location
ipad wifi cannot determine location
locate ipads last position
