Sound? I've lost my sound! Help! Please
This is a discussion on Sound? I've lost my sound! Help! Please within the iPad Help forums, part of the Apple iPad Discussions category; Not sure what is going on with my iPad. I can play music from the iPod app - hear sounds from YouTube videos. I cannot ...
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Tim SPRACKLEN
Thread: Sound? I've lost my sound! Help! Please
    10986
    2 times
    Jul 2010
    Birmingham, Al, USA
    322
    Not sure what is going on with my iPad. I can play music from the iPod app - hear sounds from YouTube videos. I cannot hear any sounds from games like Angry Birds or Trucks & Skulls or my keyboard clicks (which are all set to ON for sound). Any suggestions for somewhere I can look? It must be something dumb or simple I have done.... Thanks for any info!
    Chiky
    116 times
    15,249
    OK - I'm sure you checked you've not accidentally activated Mute - since some games mute the audio when the Mute function is activated. You're an experienced user so you'll know the Mute function is either a hard switch or soft switch. Given all those check out, how about a reboot?
    Is your iPad in a dock? Does the problem persist if you connect a headset?
    10986
    2 times
    Jul 2010
    Birmingham, Al, USA
    322
    Thanks for replying Tim! No, the mute button was not the issue. Yes, I had turned it off/ on, but.... You were right about the headphone - when they are connected I hear the Angry Birds! What have I done?
    Chiky
    116 times
    15,249
    OK - do you have a version of iOS which has a re-assignable Mute function - i.e. to the soft control? OK - just wanted to be sure, don't get mad....
    I would then try a power-off, power-on reset - it really does cure so many problems.
    Beyond that, I'm starting to run out of ideas...
    10986
    2 times
    Jul 2010
    Birmingham, Al, USA
    322
    Hey... I would never get mad!! Not that kind of girl!!! The iPad shows the version as 4.3.5 (8L1) a does that tell you anything? Thanks for your help!
    116 times
    15,249
    OK - so you've got a version of iOS that has a re-assignable Mute switch. Double press the Home button to open the multi-task bar, flick the screen to the right and see what the button on the very left of the screen in the multi-task bar is assigned to. It's possible it's been set to the Mute switch here (because, with this version of the operating system you can change the allocation of Mute from the hard switch next to the volume control to the soft switch in the multi-task bar. That change can be made in the 'Settings' menu and some Members have found they've 'accidentally' switched the function from hard to soft switch. Hence the hard switch would then control the orientation lock instead.
    The mute function leaves the headphone connection unaffected so that's why, even with Mute set (if, indeed, it is) you can still hear the games via the headphones.
    OK - if I've made a big mistake here and it's not the Mute function (a) forgive me and (b) we'll try some other things....thanks for your patience...
    Mistyvenus likes this.
    10986
    2 times
    Jul 2010
    Birmingham, Al, USA
    322
    Tim! You need your superman pic back out there!!!! For sure YOU are my hero! That WAS it! All sounds seem to be back! That was the one place I never looked (double clicking the home button...nothing showed in settings). Thank you so very much. Can't stand for anything to be wrong with my iPad!
    Chiky
    I love this forum!
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    Tim is our hero to be sure.
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    97982
    Sep 2011
    Middle of Nowhere, Montana
    Thanks so much, Tim! I had the same problem today after doing a reset and was about to go mad trying to figure out what went wrong. You're my hero of the day for sure!
    176142
    Mar 2012
    Thanks, tim that solution worked for me as well.
    Sent from my iPad2 using the iPF App
  1. Lost sound in games
    By Tokkie in forum iPad Hacking
    Last Post: 07-06-2011, 05:14 PM
  2. Help no sound
    By Harley7788 in forum iPad Help
    Last Post: 05-18-2011, 02:26 PM
  3. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
cant hear sound on ipad
i can't get sound on my ipad
i can't hear any sound on my ipad
i can't hear anything on my ipad
i can't hear sound on my ipad
i can't hear sounds on my ipad
i cant hear anything on my ipad
why can't i hear anything on my ipad
why can't i hear sound on my ipad
why can't i hear youtube videos on my ipad
why cant i hear anything on my ipad
why cant i hear sound on my ipad
