Ipad 2 and usb stick
This is a discussion on Ipad 2 and usb stick within the iPad Help forums, part of the Apple iPad Discussions category; Have just tried to connect a USB stick to my ipad2 using the connector kit I bought with the ipad2. However it acme up with ...
Results 1 to 10 of 10
    64701
    Jun 2011
    Cyprus
    27
    However it acme up with the message 'this stick needs more power'
    What's the solution to this??????
    116 times
    15,249
    The iPad camera connection kit provides only 10 mA of current to any attached peripheral. Most memory sticks require more than this and simply cannot be used with the iPad. You'll find several threads on the Forum where Members discuss the newer low-power USB sticks that will work with the iPad. The older, high-power, versions simply consume too much power for the iPad.
    94284
    Sep 2011
    14
    You could try a powered USB hub...
    116 times
    15,249
    Good idea!!
    64701
    Jun 2011
    Cyprus
    27
    Good idea!!
    Thanks for your replies..I didn't realize there were lower powered USB sticks... Off to spend some more money then...
    116 times
    15,249
    Yes - but be careful because only a few have such low power requirements. It might be worth reading the comments from Members on the sticks that work and those that don't. The USB hub was a good idea too because it would then work with any stick.
    20755
    7 times
    Nov 2010
    Michigan
    436
    I just read about this... Check out I-FlashDrive from Photofast. Looks like it might fit the bill. I don't have a link, but bet you could google them. Said to be designed specifically for iPhone, iPod and iPad.
    64701
    Jun 2011
    Cyprus
    27
    USB ipad
    Tim and Jeeper.. thanks for your replies!! Most helpful as usual!
    64701
    Jun 2011
    Cyprus
    27
    Usb $$
    Found the USB suggested... a tad expensive at over £70 or about $130
    116 times
    15,249
    Quote Originally Posted by slipknot View Post
    Wow......
    Powered Hub is a cost-effective solution....
    That IS expensive...
  1. Movies from usb stick to ipad
    By robo 4g63 in forum iPad General Discussions
    Last Post: 11-15-2012, 09:45 PM
  2. Memory stick fo ipad & other apple devices ?
    By pandcinsing in forum iPad General Discussions
    Last Post: 08-20-2011, 02:07 AM
  3. Connect iPad to xbox like memory stick?
    By dave3lions in forum iPad Hacking
    Last Post: 07-17-2011, 03:48 PM
  4. Ipad compatible USB Stick
    By Kjyjan in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-25-2011, 09:31 AM
  5. SD, Memory Stick and CF card all work with iPad
    By thehatguy in forum iPad General Discussions
    Last Post: 11-13-2010, 07:22 PM
can you use usb stick ipad
connect usb stick to ipad
how to connect ipad2 to usb drive
how to connect usb stick to ipad 2
ipad 2 usb drive
ipad usb stick
low power usb drive
usb drive on ipad 2
usb drive to ipad
usb stick an ipad 2
usb stick and ipad 2
using usb stick with ipad 2
