need help with maps
This is a discussion on need help with maps within the iPad Help forums, part of the Apple iPad Discussions category; Hi everyone, I have an ipad 1 and just today the maps icon quit working. when i touch icon it goes to the grey screen ...
Results 1 to 6 of 6
    96649
    Sep 2011
    need help with maps
    Hi everyone, I have an ipad 1 and just today the maps icon quit working. when i touch icon it goes to the grey screen like its loading then in 3 seconds or so it goes back to home screen. Any advice/ help would be greatly appreciated.
    thanks
    579 times
    Dayton, WA
    13,187
    Try restarting your iPad. If that does not work try a reset.
    96649
    Sep 2011
    I'm sorry to say that the restart and reset did not correct the problem. Thank you for the help twerppoet... I atleast learned how to do a restart and reset. Thanks!
    Any other suggestions anyone?
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Hi Jill (my assumption) - welcome to the forum!
    TP's suggestion is excellent, i.e. if your iPad is acting up in a 'funny way', then follow those sequences - sorry, that the directions did not work - make sure that the 'reset' worked?
    Just as a suggestion (which should have been corrected by the previous maneuvers), double-click on the 'home button' which will bring up a task bar at the bottom of your home screen - press & hold any app there until all being to jiggle - find the 'Map' icon and press the little x (upper left corner) - this will force a shutdown - now this may not even be a choice? But if so, let us know if this help - if not, then repost back here - good luck!
    96649
    Sep 2011
    Hi giradman thanks for the"welcome"
    I followed your instructions of doing the double click home button and xing out of
    all my apps (literally all my apps were running) So thanks for that lesson!
    I then did another reset but no success.... Maps still not opening
    Jill
    579 times
    Dayton, WA
    13,187
    Not all your apps were running, but we'll not get into that now.
    The next step down the road is a restore. This will wipe your iPad clean and restore it to factory defaults. You'll have to enable just like you did when new.
    If you are uncomfortable with this and still within 90 days of your iPad's purchase, or you got the Apple Care extended protection you can contact Apple Support and have them walk you through.
    Here is what I suggested in another thread when asked about restoring. I'm lazy.
    Save all important files off the iPad before restoring. You may be able to recover them with a restore from backup afterwards, but don't take a chance. Before you restore, make sure you get a good backup in iTunes. This will give you the best chance of getting your iPad back in order with the minimum of fuss.
    Backing up in iTunes is easy. It does one every time you sync. Before you do the last backup, right click on the iPad in iTunes and choose Transfer Purchases. You can force a backup the same way.
    When you are ready and sure all you important files are saved either in iTunes or elsewhere, all you have to do to restore is choose Restore from the summary page. When it is finished your iPad will look exactly like it did when it came out of the box.
    When you connect the iPad to iTunes after the restore it will want to set it up again. It should offer you a chance to restore from a backup, just like it did when you set your husband's up. Choose your backup and let it do its thing. Before you sync, go through all the sync pages and make sure they are setup the way you want.
    You may end up having to do some minor tweaks to get everything back, but most of it should be fine.
    For more information here is Apple's help page on backups and restoring your iPad.
    iTunes: Backing up, updating, and restoring your iPhone, iPad, or iPod touch software
  1. Upgrade Your Native Maps Application With 'Dashboard For Maps'
    Last Post: 08-29-2011, 04:45 PM
  2. Maps..... Need some help!
    By Tsouthern in forum iPad General Discussions
    Last Post: 04-11-2011, 03:49 PM
  3. Maps use 3G?
    By Hookem62 in forum iPad Help
    Last Post: 03-02-2011, 11:44 PM
  4. Saving Google Maps User Generated Content on iPad Maps
    By sandis01@yahoo.com in forum iPad General Discussions
    Last Post: 09-27-2010, 07:30 PM
  5. how do I transfer Google My Maps user content to ipad "Maps"
    Last Post: 09-27-2010, 04:43 PM
apple maps commands
apple maps help
google maps help ipad
google maps ipad help
help file for ipad map
help with ipad maps
how to reset google maps on ipad
how to restore maps on ipad
ipad maps help
reset ipad maps
reset maps on ipad
restore map icon on ipsd
