I must have had beginners luck since I had my voyager pro+ Synced with my iPad last week. Now I can't get my iPod audio to stream from the iPad to the headset. What did I do wrong. I also have a droid x paired with the headset.
This is a discussion on Trying to pair voyager pro + to ipad within the iPad Help forums, part of the Apple iPad Discussions category; I must have had beginners luck since I had my voyager pro+ Synced with my iPad last week. Now I can't get my iPod audio ...
Cant have em both paired at the same time...
Sent from The Droid... The one you were looking for...
Life begins, and spirits rise,
and they become memories that vaporize,
and the vapor becomes the dreams we devise,
and while we are dreaming...
Time flies...
The Pro + does what's called multi point connect. It can be paired to up to 8 devices at once but only 2 connected at a time and only 1 actively being used at a time. This can be problematic if the X was the last one being actively used or first one paired when new.
When you got the Voyager Pro +, which did you pair to first? The X or the ipad? The one you paired first, the unit will see often as the primary and the secondary often has less functionality when both are connected but idle. Mine will give me a fit sometimes, sometimes work fine for music on more than one device.
Make sure the X is not idly connected to the Pro + by turning off the bluetooth on the X
if that doesn't solve it try deleting the pairing of the X, use the ipad music for a little bit then repair to the X
Hope that helps
Support Our Troops!!!
This post was Tapatalk approved
Sent from this Galaxy
I unpaired the pro+ from the droid. I'm trying to pair the pro to the iPad and all it says on the iPad is "now discoverable" with the little circle going around. The pairing lights on the pro+ never stop flashing. What's up with that?
Isn't it already paired to the ipad? It's looking for something new
