Ipad No audio from speakers (dock connected problem)
This is a discussion on Ipad No audio from speakers (dock connected problem) within the iPad Help forums, part of the Apple iPad Discussions category; One months ago, my IPad first generation has began to stay always "dock connected" also if physically it's not, and with no sound from the ...
Results 1 to 10 of 11
    94522
    Sep 2011
    Italy
    7
    Question Ipad No audio from speakers (dock connected problem)
    One months ago, my IPad first generation has began to stay always "dock connected" also if physically it's not, and with no sound from the speakers.
    I cannot turn up the volume, because it doesn't work.
    I have already done everything, like soft reset, hard reset, reboot the system from iTunes, but the audio still doesn't work.
    The headphones works.
    It's not the mute button, but seems to be something about the soft.
    The speakers works only with an app called MORFO.
    Somebody could please help me solve this problem?
    Thank You
    Cosmicman
    116 times
    15,249
    OK - remember that the Mute function can also be activated by the soft Mute button in the multi-task bar. Have you checked that?
    94522
    Sep 2011
    Italy
    7
    HI Tim, sure I did.
    Actually I tried to do almost everything. I called Apple as well, but they didn't help me. Unfortunately my IPad is out of warranty, and if I send it to Apple they are going to charge me 300 Euro. I would like to avoid that.
    I thought, ther was a way to fix it by downgrade the firmware or something like this, but I discovered that it's not so easy.
    116 times
    15,249
    This is, indeed, a strange problem because - since you can get audio from the speakers from one app - it's clearly not a hardware failure.
    OK - let's recap
    You've done a complete power-off, power up.
    You've closed all the apps in the multi-task bar - you have to do them one-by-one.
    You've rebooted (turn iPad off, then press and hold the Power and Home buttons for an extended period until the white Apple logo appears)
    You've checked the Mute switch assignment in the 'Settings' menu and ensured that Mute is not activated.
    You've remembered that the volume setting for speaker and headphone are independent - so the headphone can be on full volume when plugged in but, when you pull the headphones out, the iPad will remember the last speaker volume setting, which could be zero.
    580 times
    Dayton, WA
    13,189
    Take a pen light and a magnifying glass and look closely at the dock connector for pin damage. There are audio pinouts there, and if they are shorted the iPad will be convinced that you've got a dock speakers connected.
    The headphone jack probably overrides this, but nothing else is likely to.
    Since it is an iPad 1, this should not be too hard to repair. Check out ifixit.com if you want to try yourself, or if not technically inclined look around for a reliable third party repair shop.
    94522
    Sep 2011
    Italy
    7
    This is what I think as well.
    I've done all the steps You mentioned several times.
    As You wrote, I thought the problem was not about the hardware but about the software. Maybe, one of the system update I have done is not working with my Ipad.
    But when You try to downgrade the firmware from the 4.3.5 which I have, to 4.3.1 for example, I-tunes don't permit You the downgrade and let You restore the 4.3.5 release. Probably because somebody Jailbroken his own Ipad with previous release of OS.
    Anyway, for this reason I'm not able to install a previous release of the OS that probably could solve my problem.
    Thanks for trying to help me
    94522
    Sep 2011
    Italy
    7
    Thanks Twerppoet, tomorrow I'll check it out the dock connector and eventually how to fix it on the site You suggested.
    I'll let You know.
    Thanks again
    94522
    Sep 2011
    Italy
    7
    I have checked the dock connector, and there is no pinout shorted or damaged.
    Maybe the problem is there but it is not so visible for me.
    Right now I'm looking for a repair shop close to my area.
    Anyway, thanks for your help
    580 times
    Dayton, WA
    13,189
    Ok. Sorry I don't know of a better fix, and I hope that this will actually fix the problem. I'm not confident that it is a hardware problem, but there isn't much more you can do in the way of software repair than a restore.
    You did try that, right?
    It's a pain to get everything back the way you want, but it does not cost anything.
    94522
    Sep 2011
    Italy
    7
    yep, I've already tried several times but the problem persist.
    The only way is using the headphones.
    Hope to find a solution....
  1. ipad 2 dock with clock and speakers
    By veggiop in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-21-2011, 11:08 PM
  2. iPad headphone audio v dock audio; is there a difference?
    By Pagliacci in forum iPad General Discussions
    Last Post: 04-09-2011, 09:26 AM
  3. iPad dock with speakers
    By parias1126 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-06-2011, 02:59 PM
  4. Jensen Ipad dock with speakers
    By Debragail in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-18-2011, 02:14 PM
  5. Ipad dock speakers etc
    By MaiaWeb in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-31-2010, 03:35 AM
apple ipad no sound stuck on dock connector
ipad 2 no sound dock connector
ipad has no sound and thinks it's connected to the dock connector
ipad no sound dock connector
ipad no sound from speaker
ipad speaker dock problems
ipad thinks it's docked
ipad thinks its docked
iphone notes disappeared
my ipad thinks it's hooked to a dock connector
my ipad thinks its connected to a dock connector
speaker ipad connect working dock
