Garageband recording question
This is a discussion on Garageband recording question within the iPad Help forums, part of the Apple iPad Discussions category; Hey everyone my question is there a way and if so what do I need to record through garageband and not pick up through the ...
Results 1 to 5 of 5
    94347
    Sep 2011
    Hey everyone my question is there a way and if so what do I need to record through garageband and not pick up through the speaker?
    Example...I am trying to record our pastor to make podcast so we are ran from our sound board with a 1 4 cable with a 3.5mm adapter into the ipad.
    When we record it still picks up the people talking by the ipad!
    Is there a way around this or to stop it?
    I have tried messing with noise gate etc no luck
    116 times
    15,249
    I''ve copied this across to the Help section, where I think you might receive better attention.
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by huber View Post
    The iPad requires something it recognizes as an actual microphone input or it will keep the external mic on.
    Here is a pretty decent article discussing how to set up the iPad up for audio recording...
    External Microphones for iPhone 4, iPad and iPod Touch Audio input | Life is a Prayer.com
    Also, I'm not sure if Garage Band is the best app for what you're trying to do. I've read a couple of positive posts about these apps..
    MultiTrack DAW for iPhone, iPod touch, and iPad on the iTunes App Store
    StudioTrack for iPad on the iTunes App Store
    This company sells a mic specifically made for the iPad...
    iRig Mic
    I'm sure there's other apps, equipment and more options so others folks may have some additional advice.
    Welcome to the forum and hope that helps!
    94347
    Sep 2011
    Rich thanks for that info I will check it out. I have seen the iRig mics but the way we are set up it would be easier to have it ran through the sound system as we use cordless mics now. I will check out and see if any of these fixes it for me
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Sounds good. I didn't go through the article in detail but I believe it shows how to connect the iPad to a sound mixer/board (I believe using an adapter) that will disable the iPad's built-in mic. If you Google it I think you'll find some other advice as well.
    On a side note, you may have already seen them, but I always get a kick out of watching the videos from this one church's "iBand" which uses iPads and iPhones exclusively to create some pretty awesome music. Here's one example...
    Best of luck and let us know how it goes!
  1. All About Music And Recording
    By ipfuser55 in forum iPad Apps
    Last Post: 11-10-2012, 07:13 AM
  2. GarageBand question
    By ejbpesca in forum iPad General Discussions
    Last Post: 07-22-2011, 12:20 AM
  3. Question on Garageband
    By mobi1 in forum iPad Apps
    Last Post: 06-19-2011, 07:18 AM
  4. Voice Recording App
    By Knightoftheapp in forum iPad Apps
    Last Post: 04-28-2011, 10:53 AM
  5. Recording app?
    By ashry in forum iPad Apps
    Last Post: 10-30-2010, 03:32 PM
garageband forum recording
garageband mixer board
how do i connect my mixing board to my garageband
how do you connect a mixing board to garageband
how to turn off ipad mic in garage band
ipad and garageband onboard microohone
ipad garageband external mic
mute ipad microphone in garage band
record from mixer garageband ipad
recording from sound system to garageband ipad
turn off recording in ipad garageband
use external microphone in garageband ipad
