Results 1 to 3 of 3
    94216
    Sep 2011
    Nuneaton
    Bt Infinity wireless issue help please
    I have Just tried to connect to a new BT infinity home hub but even though the network key is correct and I have a good signal the Ipad2 will not connect to the web in any app ?
    Any ideas please ??
    116 times
    15,249
    Are you able to connect to the Internet with any other WiFi device?
    I have moved this thread to the Help section, where I think it will receive better attention.
    76661
    4 times
    Jul 2011
    Oregon
    272
    AJ,
    Connecting, via WiFi, or Bluetooth to the Internet is a two part process. First the connection of the Client (iPad) to the Host (WiFi/BT router, Wifi/BT enabled modem, iPhone, or the like. Then the Host's action of assigning the proper IP addresses so that the Client will have a path out to the internet. The initial connection might be made fine, but the second part - the Gateway address, and DNS addresses - might not get transfered. In which case, there will seem to be a connection, but the Internet just won't respond.. When using WiFi, it is ease to look and see if all the IP addressing is properly established. When using Bluetooth on the iPad, that's not the case.
    (( EDIT )) I just disconnected my normal tether connection (WiFi) and tried to re-establish it through the Bluetooth setup (to my iPhone) and it's so tricky, that I couldn't get it to work out at all this time. I can get it, but have to try, and try, and try some more to re-learn the EXACT sequence of steps. I have MiWi and their Bluetooth-based MiWi OnDemand apps, and it's a BEAR, until the connection gets established the first time, then it gets easier.... unless you don't use it for some time (like me) and have to learn how to do it all over again.
    The iPad (and especially the iPhone, when being used at the tethering agent for internet access) is really fussy about the sequence of steps that are required to get it all going right. Please give us a description of what you are doing to get connected. I won't say that I'll have a solution, even knowing that, but someone here might - hopefully.
    Brian - Sent from my iPad using iPF
    Brian
    (sent from my iPad)
  1. Apple wireless keyboard issue
    By gores95 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-16-2011, 07:06 AM
  2. Wireless router connectivity issue
    By ls224 in forum iPad Help
    Last Post: 06-29-2011, 09:33 PM
  3. Wireless issue
    By spartanmook in forum iPad Help
    Last Post: 06-19-2011, 01:10 PM
  4. Infinity Blade for iPad 50% off
    By ipadgamer in forum iPad Games
    Last Post: 03-02-2011, 09:47 AM
  5. Infinity Blade is out in USA!
    By korkidog in forum iPad Games
    Last Post: 01-12-2011, 07:08 PM
bt infinity ipad
bt infinity wireless key
bt infinity wireless key not working
bt problems ipad
infinity
infinity wireless internet key
installed bt infinity noe ipad wont connect
ipad 3 wireless wont join infinity gateway
ipad wifi drops bt infinity
ipad won't connect to bt infinity
iphone wifi connection problem bt infinity
tethering drops connection
