PDF doesn't load properly via Safari...HELP
This is a discussion on PDF doesn't load properly via Safari...HELP within the iPad Help forums, part of the Apple iPad Discussions category; I tried loading PDFs document through Safari, but it doesn't load correctly. The loading bar will be idle halfway, along with the PDF file. On ...
Results 1 to 3 of 3
    93817
    Aug 2011
    On the same note, certain websites loads halfway when you click on links.
    Any help will be greatly appreciated.
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Hi there and welcome.
    It could be that your Internet connection is weak, I have had this recently however you may just need a reboot, turn your iPad off then press and hold the home and on/off buttons together until you see the Apple logo, this may take a little while, then wait for your iPad to restart.
    Also, please don't multi post the same question, it is bad forum etiquette as well as being against the rules.
    There is lots of good advice and info on here plus plenty of members all too willing to help with any problems.
    Remember, search is your friend.......and please don't forget to read the rules Forum rules - everybody please read!! & hacking section rules for all you jail breakers (and would be jail breakers) HACKING SECTION RULES - please read.
    We also have an app for this forum. A link to download the app is: Discussion Forum for iPad Users for iPhone, iPod touch, and iPad on the iTunes App Store
    119 times
    15,248
    Are these very large PDF files? If so, you might want to try another way to download them - such as GoodReader.
    Also, just in case, try the 'fix most all problems' solution of completely powering the iPad off then on again, rather than simply putting the iPad to sleep.
  1. iPad Safari won't load, closes immediately
    By Melnima in forum iPad Help
    Last Post: 01-07-2014, 07:23 AM
  2. Doesn't sync properly, driver not found
    By Lisajo in forum iPad Help
    Last Post: 01-01-2011, 11:50 PM
  3. Safari not loading properly...
    By Celos in forum iPad General Discussions
    Last Post: 01-01-2011, 12:49 AM
  4. Replies: 1
    Last Post: 09-06-2010, 10:00 AM
ipad 2 doesnt load pdf
ipad open large pdf safari
pdf doesn't open in safari
pdf doesnt open all the way on ipad
pdf not loading properly on ipad
pdfs wont fully load on ipad
safari doesn't load pdf
safari doesn't open pdf
