Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By twerppoet
Thread: Speaker/headset plug input volume problem
    84361
    Aug 2011
    When i use my ipad using my speaker or headset i clearly have a sound, but when i unplugged it there is none i was thinking maybe i have to sync the updated apps to my itunes? right now am listening to a radio station using the speakers, i decided to unplugged the speakers and holla! Same old story no sound at all.
    Sent from my iPad
    93555
    Aug 2011
    Quote Originally Posted by j_fern
    Sent from my iPad
    I'm having the same issues have you figured anything out?
    iPad Wizard
    49745
    384 times
    6,682
    Sometimes you unplug a speaker or headphones and it sends the volume down to zero. Try manually adjusting volume from the control bar at the bottom. If that doesn't work, maybe someone else can offer insight.
    624 times
    Dayton, WA
    13,312
    When you try to adjust the volume (without the headset or speakers plugged in) what does it do? If it says 'headset' above the icon when adjusting it still thinks you are jacked in. Bad news this. It's hard to make it go away.
    BTW, it keeps a different volume adjustment for both the headset and internal speakers. Adjusting one does not adjust the other.
    Also make sure you are not muted. This should not affect the iPod app, but some third party apps will must music and audio (even though they should not) when mute is on. Mute is either set with the switch above your volume rocker, or in the Multitask bar (double tap the home key then swipe left to right for the controls).
    You can change this in Settings > General > Use Side Switch to: Whatever it's not set to is what the Multitask bar is set to.
    62766
    2 times
    Jun 2011
    Washington state
    79
    Also, some apps cause sound to "pause" when headphones/speakers are unplugged. Might check that.
    Beyond here, there be dragons.
    113594
    Oct 2011
    I am having the same problem, it indeed says "headphone" over my volume bar... Even if its hard to make it go away, I really want it to work. HELP!
    624 times
    Dayton, WA
    13,312
    Quote Originally Posted by KWEIGAND View Post
    It's hard to fix because it's a hardware problem. I googled it a few months back when my iPhone did this, and the general consensus seems to be dust in the headphone jack; especially if it has a chance to get damp and cling. I never did hear of a sure way of dealing with it, and I don't recommend sticking stuff down the headphone jack to clean it.
    Some people had luck by just plugging and unplugging their headsets repeatedly. And tried this and air (a dry computer air blower). Nothing worked, and then the next morning it was working again. So I don't have a solution for you, nor do I remember anyone posting a solid solution.
    Google it, or contact Apple. They may have a suggestion. If the iPad is less than a year old (or you have Apple Care) you're still in warrantee and they may replace it if it can not be fixed.
    KWEIGAND likes this.
    113594
    Oct 2011
    Thanks for the insights. If Apple offers a solution I will be sure to share it. Thanks again!
    149615
    Jan 2012
    Hey my FaceTime in my iPad 2 isn't working can someone please help
  1. Problem with volume (down) control
    By jmarkhenrik in forum iPad General Discussions
    Last Post: 03-17-2013, 07:14 PM
  2. Speaker problem
    By rajanipad2 in forum iPad General Discussions
    Last Post: 08-14-2011, 07:58 AM
  3. Speaker problem!
    By Hedgehog in forum iPad Help
    Last Post: 06-06-2011, 02:49 PM
  4. Replies: 19
    Last Post: 03-14-2011, 10:16 PM
how to change headset settings on ipad
ipad 2 thinks headphones are plugged in
ipad says headphones plugged in
ipad thinks headphones are plugged in
ipad volume says headphones
plug in speaker, headset or headphone connection
plug in the speaker headset or headphone
plug in the speaker, headset or headphone
plugin the speaker headset or headphone
switch the sound input on my ipad to headphones
the speaker headset or headphone is unplugged
why does my ipad volume icon say headphones
