1st Gen iPad won't sync/charge from USB or Adapter
This is a discussion on 1st Gen iPad won't sync/charge from USB or Adapter within the iPad Help forums, part of the Apple iPad Discussions category; Just started yesterday. Pulled iPad off the charger and it was at 71%. Did not think much about this at the time, but it was ...
Results 1 to 4 of 4
    7046
    3 times
    Jun 2010
    434
    1st Gen iPad won't sync/charge from USB or Adapter(FIXED!)
    Just started yesterday. Pulled iPad off the charger and it was at 71%. Did not think much about this at the time, but it was on charge for several hours, so should have been 100%
    Plugged into the PC, and will not charge or sync. Tried multiple USB ports, and 2 different cables. Reboot did not help either. This was a refurbished
    iPad I just got a few months ago, however I think warranty is gone in June, as that is when I bought the 1st one in 2010.
    Have to go in for service?
    FIXED IT, POST BELOW...
    2 - 16GB WiFi iPads
    32GB iPad Mini
    119 times
    15,248
    OK - you say you've tried a reboot - but, by this, do you mean - turn the iPad off, press Home and Power together for an extended period until the white Apple logo appears and then let it reboot?
    OK - you say you've tried multiple cables. When you plug into the PC, does nothing happen or do you get the 'Not Charging' message in the top menu bar?
    7046
    3 times
    Jun 2010
    434
    Port is bad. Took it to the Apple store to have them look at it. They wanted to charge 260$+tax for another refurbished unit.
    Going to do a little research for parts and will just replace the dock port myself.
    2 - 16GB WiFi iPads
    32GB iPad Mini
    7046
    3 times
    Jun 2010
    434
    Fixed it. Pulled iPad apart, and removed 2 screws holding dock connector in. I also reseated the dock connector where it attaches to the main board, and my iPad is now charging and restoring as we speak....
    2 - 16GB WiFi iPads
    32GB iPad Mini
  1. Ipad wont sync or charge
    By csstimk in forum iPad Help
    Last Post: 12-03-2010, 10:05 PM
  2. Jailbroken iPad Won't Sync With iTunes or Charge
    By hotphoenix in forum iPad Help
    Last Post: 11-25-2010, 07:38 AM
  3. Sync And Charge On A PC?
    By jimt29 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-14-2010, 10:35 AM
  4. Sync And Charge On A PC?
    By jimt29 in forum iPad General Discussions
    Last Post: 05-09-2010, 07:35 AM
1st generation ipad won't charge
first gen ipad won't charge
first generation ipad wont charge
ipad 1 will not charge or sync
ipad 1st gen wont charge
ipad 1st generation won't charge
ipad first generation won't charge
ipad first generation wont charge
