Results 1 to 8 of 8
    5848
    Jun 2010
    Using iPad to post on eCollege
    Good evening,
    I am unable to post my response to a threaded discussion question on a class I'm taking via the eCollege online platform. I'm able to click on the "check spelling" and "cancel" buttons, however when I click on the "post" button, it does not post my reply nor give me an error message. I'm interested in ideas that might help me resolve this issue.
    Thank you.
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    This is what I found:
    eCollege Minimum Feature Requirements
    The following components are needed to access certain features of the system. You will be able to access your course without these; however, you may not be able to access the specific feature. Before downloading any of the applications below, we suggest you check with your instructor to make sure the feature is used in your course.
    Microsoft Windows Macintosh OS ClassLive (synchronous tool)
    Supported Browser Plug-ins
    Supported Browser Plug-ins:
    Assistive Technology:
    Seems like you need Flash to use it. Just for the record, I don't know from experience...I just googled "ecollege system requirements" and looked at the first result.
    3319
    2 times
    Apr 2010
    399
    I'm sure you would have noticed if Flash was an issue, so my guess is your just trying to post to a study group MSG board (like this board)?
    I have noticed that some web apps don't play nice with/like Safari, so I use Atomic which can pretend it's a desktop browser. That might help. Or the MSG board may have a "basic" mode, like GMail does, that works better.
    14002
    Sep 2010
    Woodbridge, VA
    I have experienced the same dilema and would love to be able to post on the discussion threads during my commute...one of my main reasons for buying the iPad (school) :-) If you experiment and find a solution, I would be curious...thanks!
    13035
    Aug 2010
    17
    All my online classes are on the "blackboard" or "webct" platforms. For the most part the iPad works fine with them except for not being able to attach assignments.
    I have had a problem with discussions ones and it worked fine after I cleared safaris cache of history, cookies etc. Might help but it might do nothing at all. Either way it's work a try.
    15725
    Sep 2010
    Us
    Workaround
    I was able to post after I turned debug on. Settings-safari-developer-debug-on
    66533
    Jun 2011
    Williamsburg, VA
    Posting to eCollege
    Has anyone found a solution to this yet? I have tried everything that was mentioned above and nothing has worked yet. I was able to post to eCollege once using the free version of Atomic, but when I purchased the full version it didn't work. I then reverted back to the free version and that stopped working as well. Any help/advise is welcome.
    38384
    southport, fl
    7
    Quote Originally Posted by Ragankel
    I have found no solution. The tech support at Walden University said that their ecollege platform is officially read-only for IPad. They had no further information. Pearson, the folks behind ecollege, have other things in the works, but there is nothing on their website about anything specific to IPad, or my college.
  1. eCollege and iPad
    By mfinkenberg in forum New Member Introductions - Site Assistance
    Last Post: 05-14-2010, 02:32 PM
  2. eCollege and iPad
    By mfinkenberg in forum iPad Help
    Last Post: 05-13-2010, 09:24 AM
can you do ipad with devry
can you use an ipad at walden university
devry app for ipad
devry for ipad
devry ipad
devry ipad app
devry online ipad
devryu.net ipad
ecollege ipad
ecollege ipad app
ecollege will not allow my ipad to respond
using ipad on devry online classes
