How to improve my iPad wifi signal strength ?
This is a discussion on How to improve my iPad wifi signal strength ? within the iPad Help forums, part of the Apple iPad Discussions category; Hi All I have iPad and iphone 3 , I alway stay in one hotel in KL they provide free wifi access . My iphone ...
Results 1 to 9 of 9
    Banned
    10959
    Jul 2010
    singapore
    348
    Hi All
    My iphone 3 alway can get the wifi and I can use it for send email.
    My question is how to make iPad also can get the wifi ?
    Paul
    579 times
    Dayton, WA
    13,187
    This is mostly governed by the hardware, and there is nothing much you can do about it.
    Sometimes the software can get a little tweaked. In that case you can try going into Settings > General > Reset, and Reset all Network Settings (you will have to log into all you networks again). But this rarely makes a difference. In the end, you just have to move closer to the router, and/or try different spots in the room.
    Banned
    10959
    Jul 2010
    singapore
    348
    Hi Sir
    Thank for away advise me.
    But the issue is I have iphone 3 , iphone 4 and iPad . Except iphone can alway access the wifi signal when I in side my study room .
    I search you tube one person said by adjust the vol to highest to improve the signal strength .but it does not work.
    Paul
    579 times
    Dayton, WA
    13,187
    The iPhone has considerably better Wi-Fi reception than the iPad. That is simply true. It's no different than any other radio. Some work better than others, even from the same manufacturer. Sometimes even between the same kind of device.
    If you really feel the iPad has substandard wi-fi reception you should take it in and have an Apple tech look at it; but don't get your hopes up too high. Like I said, iPads just don't have the best wi-fi reception among mobile devices. Almost any phone is better. Why that is? I'm not engineer enough to guess.
    As for the person with the volume adjustment, I'd have to see that myself. Sounds about as likely to work as wearing tinfoil on your head.
    Banned
    10959
    Jul 2010
    singapore
    348
    Okay I will look for repeaters to boots up the signal strength. In case you aware , hope you can share with me, so my house every Conner can suf the net.
    Paul
    579 times
    Dayton, WA
    13,187
    The only network extenders I am familiar with are Airport Expresses, and I'm not certain you can use them with anything but the Airport Extreme, and I'm about five years behind the curve.
    In short, sorry, I can't be much help there.
    Banned
    10959
    Jul 2010
    singapore
    348
    It is okay I will consult hardware store.
    Paul
    579 times
    Dayton, WA
    13,187
    After you consult the hardware store, go online and search for the suggested router's model number and iPad. A few routers don't play nice with iPads, and the store person may not be aware of which ones those are.
    Banned
    10959
    Jul 2010
    singapore
    348
    Hi sir
    Thank you for your advise.
    Paul
  1. Numeric 3G signal strength?
    By Mattmilw in forum iPad Hacking
    Last Post: 07-17-2011, 02:44 PM
  2. iPad Wifi Signal Strength
    By AQ_OC in forum iPad General Discussions
    Last Post: 05-19-2011, 02:06 PM
  3. Wifi signal strength
    By jwdave in forum iPad General Discussions
    Last Post: 08-20-2010, 11:59 PM
  4. WiFi Signal Strength Terrible
    By MrLee in forum iPad Help
    Last Post: 08-07-2010, 04:56 AM
  5. Wifi Strength?
    By Ray in forum iPad General Discussions
    Last Post: 04-08-2010, 09:05 AM
boost ipad wifi
boost ipad wifi reception
how to boost ipad wifi
how to boost ipad wifi signal
how to get better wifi on ipad
how to get better wifi signal on ipad
how to improve ipad wifi reception
how to improve wifi signal on ipad
improve ipad 2 wifi reception
improve ipad wifi
increase ipad wifi reception
