Results 1 to 3 of 3
    92280
    Aug 2011
    Ipad 1 3g issues on 4.3.5
    Just updated to 4.3.5 the other day and now I only get edge. Anyone else had this happen to them? Please if anyone could help I'd greatly appreciate it, thx
    622 times
    Dayton, WA
    13,312
    If you have not done so, here a few suggestions.
    1) Go into Settings > General > Reset, and Reset all Network Settings.
    2) Restart: Hold down the power button until the power off slider appears. Slide it off. When the iPad finishes shutting down, hold down the power button again until the Apple logo appears.
    if that does not work.
    3) Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart.
    And if all else fails, call your carrier's tech support and see if there is something they can reset or tweak.
    92280
    Aug 2011
    Thanks a lot! Will Trey this out as soon as I get back into 3G coverage. Hope it works!
  1. HBO GO Issues on iPad 2
    By Leighanne24 in forum iPad Help
    Last Post: 02-19-2013, 05:48 PM
  2. Ipad 2 issues
    By timleffler in forum iPad Help
    Last Post: 07-25-2011, 08:52 AM
  3. Issues with SSH for iPad
    By rotaz in forum iPad Hacking
    Last Post: 10-27-2010, 09:32 PM
  4. Anyone having issues SSH to your iPad 3G?
    Last Post: 10-24-2010, 06:34 PM
  5. How to Fix the iPad's Wi-Fi Issues
    By cimousa in forum iPad Help
    Last Post: 04-28-2010, 12:09 PM
3g not working on ipad 1 only edge
3g problem ipad 1
3g vs edge on ipad1
4.3.5 ipad gets 3g
hbo go issues
ipad 1 3g issues
ipad 1 3g problem
ipad 2 3 g problems
ipad 4.3.5 3g network problem
ipad1 3g network does not work
ipad1 3g problem
why ipad1 only edge
