iBooks Problem
This is a discussion on iBooks Problem within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I purchased two books from the iBooks store . The books were successfully downloaded and stored in the Library. However, once I click on ...
Results 1 to 2 of 2
Thread: iBooks Problem
    91669
    Aug 2011
    iBooks Problem
    Hi,
    I purchased two books from the iBooks store . The books were successfully downloaded and stored in the Library. However, once I click on either book , it opens then iBooks shuts down instantly.
    Any help?
    Thanks.
    116 times
    15,249
  1. Sync iBooks Problem
    By jasonhooper in forum iPad Help
    Last Post: 07-29-2011, 12:02 AM
  2. Replies: 2
    Last Post: 07-19-2011, 05:03 AM
  3. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
  4. Ibooks problem
    By nmpettus in forum iPad Help
    Last Post: 05-02-2011, 09:57 AM
  5. iBooks FIX iOS 4.2.1 Jailbreak DRM Problem
    Last Post: 02-17-2011, 03:00 AM
i books keeps shutting down
ibooks app keeps shutting down
ibooks keeps shutting down
ibooks keeps shutting down on ipad
ibooks problem
ibooks problems
ibooks shuts down
ibooks shuts down instantly
ibooks turns off
ipad ibooks shuts down
problems to buy in ibooks
problems with ibooks shutting down
