I chose "select all" on a note I wanted to copy into a blog, but then hit "paste" instead of "copy". Aiy, aiy, aiy, the whole thing disappeared! Is there any way to retrieve it?
This is a discussion on Retrieving deleted note within the iPad Help forums, part of the Apple iPad Discussions category; I chose "select all" on a note I wanted to copy into a blog, but then hit "paste" instead of "copy". Aiy, aiy, aiy, the ...
there's an undo button on the keyboard, you see it after pressing ?123
iPad2 3G 64GB
SHSH 4.3.3
JB
Manila, Phil
OR you can shake the iPad and you get an Undo option.
