WiFi question
This is a discussion on WiFi question within the iPad Help forums, part of the Apple iPad Discussions category; I just purchased a small netbook unit that has built-in WiFi but the unit does not connect to my home Wi-Fi. I have a Time ...
Results 1 to 10 of 10
Thread: WiFi question
    90423
    Aug 2011
    Indio, CA
    WiFi question
    I just purchased a small netbook unit that has built-in WiFi but the unit does not connect to my home Wi-Fi. I have a Time Warner cable connection for internet and a router to send the internet to my computer in another room. Doesn't this mean that any Wifi enabled unit should be able to pick up the internet signal thru the router. My wife uses a Kindle that has 3G WiFi and it works fine in our home. Any idea why this new netbook won't pick up the signal?
    88021
    Aug 2011
    Grand Prairie, TX
    10
    Quote Originally Posted by Rockman59
    I also have Time Warner cable and a Linksys wireless router.
    I have 5 desktop PCs, two WIi, two laptops, a Lexmark printer, and my iPad1 connected to the router.
    I use a Verizon wireless Hotspot for the IPad and one laptop when I travel.
    iPad 1, 32 Gbyte
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Hi Rockman and welcome to the forum -
    By a small netbook unit that has built-in WiFi, do you mean that you purchased an iPad w/ Wi-Fi? Just not clear from your description?
    If so and you indeed own an iPad (I assume an iPad2), did you go to 'Settings' and turn on the Wi-Fi and then setup your home wireless connection?
    I won't go much further until you clarify the above - should be an easy solution and good luck!
    90443
    Aug 2011
    New York NY
    Have the same problem.My WIFI stopped working on my IPad 2 but my computer works with the same internet connection. When trying to connect to Safari or email, message is "connection to server failed". I also have Time Warner cable and a Cisco wireless router. Anyone has the answer how to fix it?
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Quote Originally Posted by jmmitler View Post
    Hi Jmmiler and welcome to the forum -
    First, you have 'hijacked' the OP's thread - your problem may or may not relate to the same issue thus confusing other posters - if the problem continues, I would suggest starting your own thread w/ a clear explanation of your problem.
    But as a beginning, try re-starting your iPad (i.e. hold down the power on-off button, top right, until the power off slide button appears - turn the device off and then restart) - may offer a quick solution; if not, please start your own thread - good luck!
    95015
    Sep 2011
    Rossmoor, CA
    Has anyone resolved this issue? Although I have 3G, I use wifi all the time. The only one that I can't get to work is at my friend's home and his Time Warner cable. Like others said, I can get my Windows laptop to pick it up--even if I delete it and start over.
    It's almost like there is a different configuration setting that needs to be modified. I've tried the Forget This network multiple times and reentered the password. Yes, I have restarted the Ipad too.
    The Time Warner technical site is pretty useless, since it assumes immediate connection.
    Thanks for any additional info that you can provide, but prefer comments from those using Time Warner Cable at home.
    P.S., Has this thread moved elsewhere? I completely disagree with the poster that said someone hijacked the thread. This is a very difficult topic to search because of the competing TW app for streaming TV.
    95322
    Sep 2011
    6
    Quote Originally Posted by Kjsl61
    What kind of IPAD do you have, is it a Att or other? Each has different ways to setup for Wifi.
    iPad Ninja
    62473
    62 times
    Jun 2011
    1,607
    Wifi is Wifi independently of the 3G carrier.
    AT&T, or anyone else makes no difference for Wifi.
    -t
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Quote Originally Posted by thewitt
    -t
    Agreed, wifi issues will generally be related to the router, your device or a conflict between the two.
    145982
    Jan 2012
    Garden Grove, CA
    Was just wondering if any of you figured out the issue with the wifi not connecting properly on your iPad. I have same issue with iPad 2, time Warner, cisco wireless router. All other computers/blue ray players work but iPad will not get ip address. I believe it seems like a problem with time Warner and the way they have the sbv4200 surfboard setup. Just wanted to see if any of you figured out your issue before I call time Warner.
  1. AT&T WiFi hotspot question
    By workinonit in forum iPad Carriers
    Last Post: 11-06-2011, 07:59 AM
  2. WiFi question
    By SCCAguy in forum iPad General Discussions
    Last Post: 08-10-2011, 02:36 PM
  3. used ipad 2 3g+Wifi question
    By gator99 in forum iPad 2 Forum
    Last Post: 07-06-2011, 08:48 AM
  4. WiFi question
    By mikescott1976 in forum iPad Help
    Last Post: 06-15-2011, 06:40 PM
  5. Question about wifi
    By Zaen73 in forum iPad Help
    Last Post: 03-25-2011, 09:17 AM
connecting ipad to time warner wifi
how to set up time warner wifi on ipad
ipad and time waner wifi
ipad twc problem wifi
ipad wont connect to time warner cable
time warner cable wifi connected but doesn't work
twc wifi doesn't work
unable to connect android to time warner cable wifi
unable to join time warner wifi with iphone
why my twc password on ipad stopped working
why time warner cable wifi hijacks iphone
why wont my ipad connect to time warner
