Loosing sound
This is a discussion on Loosing sound within the iPad Help forums, part of the Apple iPad Discussions category; hello, I have an ipad and it just started loosing sound. While listening to Pandora radio it would start out fine and then a few ...
Results 1 to 3 of 3
Thread: Loosing sound
    89815
    Aug 2011
    Unhappy Loosing sound
    hello, I have an ipad and it just started loosing sound. While listening to Pandora radio it would start out fine and then a few songs later the voulume would be lower and lower until I no longer have it. Also alerts will do the same they will be working fine and then suddenly stop. please help! thanks Candy
    116 times
    15,249
    89815
    Aug 2011
    Ipad Sound.
    Tim of scotland, Thank you so very much for your suggestions! The second one fixed it! i will start to power off at least once a week like you suggested also.
    I got the little plastic tip with a stylus that can be placed in the ear bud port to keep dust out. Do you think that could have hurt/
    Also can you explain why powering down at least once a week works with issues?
    thank you again so much for your help. Candy from Virginia
  1. HBO GO no sound
    By basicuser in forum iPad Help
    Last Post: 06-15-2011, 10:33 AM
  2. Wifi loosing connection
    By Misho73 in forum iPad 2 Forum
    Last Post: 04-04-2011, 07:18 PM
  3. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
ipad 2 keeps losing sound
ipad apps losing sound
ipad keeps losing sound
ipad loosing sounds
ipad losing sound
ipad losing volume
ipad pandora no sound
keep losing sound on ipad
losing volume ipad
lost volume on ipad
my ipad keeps losing sound
why does my ipad keep losing sound
