Results 1 to 10 of 14
    83561
    Aug 2011
    29
    HDMI AV Connector : IPad Stability Problem
    Hi
    Reading the various threads it appears there are problems with these connectors, anyway here goes.
    Hooked up the adapter to the HDMI input to a Sony Bravia TV and what was on the pad was seen on the TV. However when the pad is then touched I get random jumping on the pad screen and some in cases random characters being generated where input is assumed by the pad. All of which does end up on the screen. Not sure if this is an adapter problem on iOS problem. Has anybody experienced this or knows of a solution.
    Thanks in advance for any advice / help.
    Cheers
    Globalpad
    116 times
    15,249
    83561
    Aug 2011
    29
    Hi Tim
    Thanks for the Info. Putting your advice into practice certainly did improve the situation. The result: I was able to watch ITunes sourced movies Full Screen (16:9) but interestingly BBC IPlayer and Crackle Movies where wide screen format but not fully scaled to the TV say 50% of full screen. As this is the first time I have tried this I am not sure if its normal. The second situation is quite bizarre, the pad screen became very touch sensitive but not accurate make it very difficult to select things even with a stylus. Overall partial success.
    Appreciate any feedback.
    Thanks & regards
    Globalpad
    56627
    May 2011
    Michigan
    16
    I've also attached my iPad2 to my Sony Bravia HD LED TV, but have not experienced any problems with this setup. Just wanted to let you know.
    Larry
    Black iPad2, 32gb
    83561
    Aug 2011
    29
    Hi Larry
    Useful to know. What apps did you try it with?
    I suspect these connectors are not intelligent I.e. No chip inside simply a a connector with wires and problems experienced could be to do with a several things e.g. Pins, signal incompatibility. At the moment I pass my connection via an intelligent 3 way adapter as I only have 2 HDMI inputs on the TV. I shall be trying a direct feed.
    Appreciate your comments on type of apps used.
    83561
    Aug 2011
    29
    Larry sorry left something out. Do you always get Full Screen display ?
    56627
    May 2011
    Michigan
    16
    First, my main goal was to show a movie I created with iMovie on my Mac. I moved it to my iPad and tested it on my 55" TV and it worked great...full screen and all. I tested several other apps (mostly games) just to see how they displayed. Since I'm not planning to do a lot of iPad via cable to TV, I didn't pay a lot of attention whether they were all full screen, but I believe they were. I was very impressed with the HD display quality. I didn't observe any jumping as you described, but I'll watch for it next time.
    Larry
    Black iPad2, 32gb
    83561
    Aug 2011
    29
    Ok thanks for the info.
    41918
    3 times
    Southampton UK
    264
    @Globalpad
    I am very interested to know if you managed to get the iPlayer working full screen.
    I am off to Florida in 3 weeks time and plan to pick up this connector whilst I am over there, but not if it cant do full screen.
    Also, will it enable me to use the "Air Video" app to stream movies from my PC including the 5.1 audio instead of having to put them on a dongle and plug into my BR home cinema?
    iPad 2 32GB 3G T-Mobile Black (IOS 5.0)
    iMAC 27" i5 3.1Ghz (OSX Lion)
    83561
    Aug 2011
    29
    Hi Harters
    No success ! I'm still no further forward and my original post stands. For my situation the over sensitivity issue with the pad makes it unusable. I agree disregarding other issues full screen playback is essential. Maybe somebody else could jump in and confirm either way.
    With regard to the stability issue is does not seem others have reported this problem so I will approach Apple Support for advice. From the posts regarding this connector is does seem there are successes and failures so for me a bit inconclusive !!!
    Sorry not to be more helpful.
    Cheers Globalpad
  1. Replies: 7
    Last Post: 08-08-2011, 12:55 PM
  2. has anyone tried the HDMI connector with Displayout??
    By addiosamigo in forum iPad Hacking
    Last Post: 04-07-2011, 01:43 AM
  3. Problem with Real Racing2 and HDMI
    By ratatapa in forum iPad Apps
    Last Post: 04-03-2011, 01:05 PM
  4. iPad stuck at apple logo and dock connector problem
    By spygrad2003 in forum iPad Help
    Last Post: 11-27-2010, 06:41 AM
  5. Camera Connector Problem with Canon 7D
    By Sly808 in forum iPad Help
    Last Post: 10-17-2010, 09:16 AM
av connector ipad
hdmi 30sec
hdmi connector for ipad 2 problem
ipad av connector
ipad hdmi adapter issues
ipad hdmi input
ipad hdmi issues
ipad hdmi problem
ipad hdmi sony
problems with ipad hdmi
problems with ipad hdmi adapter
sonay bravia ipad hdmi
