GPS question
This is a discussion on GPS question within the iPad Help forums, part of the Apple iPad Discussions category; With wi-fi and cellular turned off how long should it typically take iPad to get a satellite signal? I do have the wi-fi + 3G ...
Results 1 to 4 of 4
Thread: GPS question
    61156
    Jun 2011
    NJ
    28
    GPS question
    With wi-fi and cellular turned off how long should it typically take iPad to get a satellite signal? I do have the wi-fi + 3G version, so out of curiosity wanted to see if I could use the GPS. Left it on for many minutes, but it never seemed to get a signal. I was in my yard with a (mostly) clear view of the sky, with a few branches between the iPad & sky.
    Thanks,
    Mark
    66612
    6 times
    Jun 2011
    Montreal Canada
    110
    I do not remember how quick it was when I got my iPad2 (wifi and 3G) but when I went to France this summer (from Canada), it sync'ed pretty fast, in phase from the Apple localization system and then to the accuracy of the gps. I certainly do not remember being long at all.
    Sent from my iPad2 3G 32 gig / using iPF
    48077
    10 times
    Illinois
    488
    Quote Originally Posted by Mark29 View Post
    Thanks,
    Mark
    You're gonna think I'm kidding ya but if it was today it could've been due to a solar flare.
    Spot-on: Massive X-Class Solar Flare Could Disrupt Earth Communication: Scientific American Gallery
    14699
    12 times
    Sep 2010
    Woodlands MB, Canada
    349
    The iPad uses assisted GPS... Assisted GPS units like the iPad and just about all smart phones have to use a tiny (and inefficient) GPS antenna. This constraint is due to the size of the device....The assistance occurs when the device gets the information needed to get a proper satellite fix from the cell towers. The cell towers keep the satellite info on file and constantly update it. This method relieves the iPad or smartphone of some of the heavy lifting. You won't get a fix as fast with 3G off, but... With a clear view of the sky, you will eventually get a GPS fix without using the cell tower system.
    Note.... If you've turned WiFi and 3G off using 'Airplane Mode', then you've turned off GPS as well.. Airplane mode also turns off the GPS receiver. This is because some airlines don't allow the use of GPS receivers while in flight.
  1. Answer the Question Above with Another Question!
    By pEAcEmAKeR in forum Off-Topic
    Last Post: 09-17-2011, 06:46 AM
  2. Game: Answer question with a question
    By BrennB in forum Off-Topic
    Last Post: 05-25-2011, 02:14 PM
