VERY slow WiFi
This is a discussion on VERY slow WiFi within the iPad Help forums, part of the Apple iPad Discussions category; I have had my iPad 2 for just 2 weeks, but my wifi speeds are abysmal. My Macbook gets 6.8 down, the iPad .72. Same ...
Results 1 to 7 of 7
Thread: VERY slow WiFi
    10706
    Jul 2010
    Maine
    VERY slow WiFi
    I have had my iPad 2 for just 2 weeks, but my wifi speeds are abysmal. My Macbook gets 6.8 down, the iPad .72. Same Airport Extreme. I spent time with Apple support -- reset network settings, everything he knew to suggest and no change. I cannot stream from Netflix or even easily watch YouTube videos with this speed. Anybody have any ideas?
    47570
    California
    73
    Try resetting the network adapters in the settings of your iPad.
    Sent from my iPad 2 using iPF.
    Apple Products:
    - iPad 2 White - iPhone 4 White - iMac 27" 2010 - iPod Video - iPod Shuffle
    - iPad 1 (Sold) - Macbook Pro 2011 (Sold) - Macbook Pro 2010 (Sold) - iPhone 4 Black (Sold) - iPhone 3G Black (Sold) - iPhone 2G (Sold) - iPod Touch 2G - iPod Nano (Sold)
    10706
    Jul 2010
    Maine
    I am not sure what you mean by "network adapters". I reset the Network settings several times. Where will I find network adapters?
    52722
    May 2011
    Mexico
    13
    Try changing your systems’s DNS servers let me give you a link for that
    http://appletoolbox.com/2010/05/ipad...youtube-fixes/
    29813
    21 times
    Quebec
    644
    When stuggling with wifi speed, there can be several problems at the same time. That's the fun of it...
    1- install from the AppStore the app Speed Test, if not already done
    2- do some speed testing with several servers. Sometimes, the default one is not the fastest.
    3- there you will see Ping time, download speed and upload speed.
    Snce your Mac has a good bandwith, then it is for sure that the ISP is not the issue. One thing you have to make sure is to validate if this is a DNS problem or a bandwith problem. You've reported speeds at 0.7 which leads me to believe that this is not a DNS issue. A DNS issue would make webpage loading very long, but once the content is reached, it would load fast. So assuming that is is not the case, we'll concentrate on data transfer speed.
    1- how many bars do the ipad shows on your wifi icon?
    2- do you loose wifi connection once in a while?
    3- in your router, what security is used? WPA, Wep, none?
    4- in the wifi settings on your router, is the channel set at auto or a fixed value?
    5- on your router, wifi settings have several parameters like boosting, auto g/b, bandwith speed (1,2,4...54)
    I would start by assigning a fixed channel, 11 seems to always do the trick. Also setting the speed at 6 for testing purpose will give view a hint if something has changed. Long preamble seems to work better with the ipad... Don't play with numerical values, they're fine for sure.
    In your iPad, select your network, and click "Forget this network" (hope that this is how it's called in english...). And reboot your ipad and re-join your wifi.
    Generally, a bad wifi speed is often related to the channel selection or the wifi speed. A lower wifi speed may help a lot if your router is far from your location. Also, remember that wireless phone may interfer with your wifi. If the base is near the router, put it in another room or simply disconnect it for testing purpose...
    Waiting for your results...
    VicoPad addict!
    iPhone 4S 16Gigs 5.01
    iPad 1 16 Gigs Wifi 5.01
    Canada / Rogers
    37110
    rmojo@mail.com
    16
    Post #4 worked for me! Thank you Zaceck!
    51917
    May 2011
    67
    hi all,
    my ipad2 just dies regularly when using wifi - pretty rubbish as it is wifi only and this is the only use for it
    heard mentioned on apple discussions forum about turning of the QOS setting on route - means quality of service i think - but mine was already off - am giving the dns ip setting change in the above link a try out now - hope that works
    cheers
    dan
  1. Why is my i pad so slow
    By carv120222 in forum iPad Help
    Last Post: 07-08-2011, 12:05 AM
  2. iPad recently VERY slow over wifi :(
    By danx55 in forum iPad Help
    Last Post: 05-20-2011, 02:09 PM
  3. Wifi connection slow and unpredictable
    By DMad in forum iPad Help
    Last Post: 12-15-2010, 01:34 PM
  4. Why does wifi connection slow down at times?
    By ipad987 in forum iPad General Discussions
    Last Post: 08-09-2010, 11:47 AM
  5. One solution to slow WiFi problems
    By Billee in forum iPad Help
    Last Post: 08-06-2010, 06:31 PM
ipad 2 slow wifi
ipad air slow wifi
ipad slow on wifi
ipad slow wifi
ipad very slow
ipad wifi slow
slow ipad wifi
why is my ipad so slow on wifi
