Storage capacity drain
This is a discussion on Storage capacity drain within the iPad Help forums, part of the Apple iPad Discussions category; Hi, im using ipad2 16gb wifi, i notice that the storage capacity is 14gb. After installing some apps i got free capacity 9.4gb. What i ...
Results 1 to 10 of 14
    85773
    Aug 2011
    Jakarta, Indonesia
    41
    Hi, im using ipad2 16gb wifi, i notice that the storage capacity is 14gb. After installing some apps i got free capacity 9.4gb. What i would like to discuss is recently i notice my free storage capacity drain approx. 0.2gb everyday. Does anyone having the same problem like me or is it because the cache things? I already trying to reboot by using
    The sleep wake button but still not increasing my free storage capacity. Can anyone help me solving this problem. Many thanks.
    116 times
    15,249
    If you perform a sync with your PC you'll be able to see what is 'taking' the storage capacity. Usually it's under a category that iTunes classifies as 'Other', which are files that iTunes cannot identify. This is a widely reported issue and most Members have found that frequent synchronisation of the iPad and PC seems to mitigate the problem to some extent.
    85773
    Aug 2011
    Jakarta, Indonesia
    41
    Hi Tim, thanks for your respond, the main issue is i dont installed another apps at the moment and the free storage is still draining. I wondere if there a step that i have totake to refresh the storage memory?
    78337
    Jul 2011
    20
    Some apps store data. If you are adding information to a text file, spreadsheet, recording sound or video, that will all take up extra space on your iPad.
    Also, some apps do have caches, but they are automatically cleared at some point, so that shouldn't be a continuing problem.
    85773
    Aug 2011
    Jakarta, Indonesia
    41
    Thanks Ace for your respond and now i feel much better lol
    85773
    Aug 2011
    Jakarta, Indonesia
    41
    One more thing ace, i recently notice my free storage drain for another 0.1gb today. As u said earlier this memory drain probably cause by cache and apps that saving memory, when its already reach the full capacity do u think my free storage will be back as the real free storage capacity that available?
    78337
    Jul 2011
    20
    The cache storage will automatically be cleared, but any space that is used by apps for images, audio, video recording will stay there until you delete them. You can usually do this from inside each app. For some apps, you have to check in iTunes as Tim said above.
    85773
    Aug 2011
    Jakarta, Indonesia
    41
    Does installing xsysinfo will do any help to restore storage and memory drain?
    78337
    Jul 2011
    20
    I haven't used that app, but it has good reviews in the app store. Perhaps it would help. If you try it, please come back here and let us know if it solved your problem.
    85773
    Aug 2011
    Jakarta, Indonesia
    41
    I installed xsysinfo and it help refreshing unused memory Like if we did some reboot. About the available storage draining i think it drains more slower than before. I notice after i stream some videos through you tube the availability storage drain about 0.1gb. I already asking to our local apple reseller in Indonesia and they said they didnt have anycompalints regarding this issue but he will try to investigate aout this and will come back to me sometimes next week. After all i think this issue cause by the ipad using the available memory for cache, apps memory like u said and etc. Probably because i still have a lot of available storage they using from this portion. Is this make sense to you?
  1. Capacity on ipad 2
    By willtrvl in forum iPad General Discussions
    Last Post: 07-05-2011, 07:58 AM
  2. itunes says over capacity ipad?
    By iRuthlessPad in forum iPad Help
    Last Post: 06-22-2011, 04:09 PM
  3. Checking storage capacity iPad2
    By cmr8 in forum iPad Apps
    Last Post: 03-13-2011, 12:40 AM
  4. App with folder capacity?
    By gouletjo in forum iPad Hacking
    Last Post: 07-01-2010, 12:34 AM
  5. iPad capacity, storage?
    By mikedatlga in forum iPad General Discussions
    Last Post: 05-12-2010, 10:19 PM
apps capacity on ipad
free available capacity ipad
free up capacity ipad
freeing up capacity on ipad 2
how to free capacity on ipad
ipad 2 storage problems
ipad other storage
ipad other storage problem
ipad over capacity
ipad storage malfunction
new ipad storage issues
what are other storage on ipad
