iPad 2 wifi issues with diagnostics
This is a discussion on iPad 2 wifi issues with diagnostics within the iPad Help forums, part of the Apple iPad Discussions category; Just received my new iPad 2 straight from Apple last night. Came with 4.3.5 preinstalled. Was tearing my hair out over connectivity issues until I ...
Results 1 to 9 of 9
    21716
    Nov 2010
    San Antonio, TX
    6
    Question iPad 2 wifi issues with diagnostics
    Just received my new iPad 2 straight from Apple last night. Came with 4.3.5 preinstalled. Was tearing my hair out over connectivity issues until I found that turning off the WEP or WPA or WPA2 - i.e. turn off all security - "fixes" it.
    So tonight I spent some time trying things with the iPad 2 and a monitor on the router.
    If ANY type of security is turned on, then the router sees the iPad 2 connect, but shows it as having the IP of "0.0.0.0". If I try to enter a static IP, this makes no change at the router, and there is no obvious change at the iPad 2. If instead I try to use DHCP, then the iPad 2 initially shows nothing. If I renew lease I then show an IP of "169.254.176.38" and a subnet mask of "255.255.255.0", although the router still sees it as 0.0.0.0.
    Once I turn off security, then DHCP works. HOWEVER, if I try to setup a Static IP it STILL does DHCP as evidenced by the fact that disconnecting and reconnecting the iPad gets an IP address that is NOT the one I have put in with the Static IP.
    Since it works without dropping with security turned off, I doubt this is a hardware issue. I am wondering if "fixing" certificates in 4.3.5 broke something else?
    61156
    Jun 2011
    NJ
    28
    Quote Originally Posted by EwanG View Post
    I'm having the same issue, though I haven't yet turned off the security on my router - need to do a factory reset, lost the password.
    I have the same problem however - even if I use a Static IP Address and type it in, I can't get internet connectivity. I've tried everything suggested other than turning off the security or replacing the router.
    BTW, I'm on my 2nd iPad - the first one didn't connect to public wi-fi spots either.
    Mark
    21716
    Nov 2010
    San Antonio, TX
    6
    Just to pre-answer a question that came up in the Apple "support" forums - this is happening on three different routers (TrendNet, Linksys, and Cradlepoint) that are working just fine with an iPad 1, a couple of iPhones, and a couple desktop computers. They all have their most recent firmware. Given that, isn't it odd to think the one thing that changed wouldn't be the problem (i.e. the iPad 2)?
    579 times
    Dayton, WA
    13,188
    This is a long shot, and I'm sure it's been tried by both of you before, but have either of you reset the ipad since the update? If you have and I missed that fact, forgive me for repeating advice; but a reset after an update often clears up unusual problems.
    21716
    Nov 2010
    San Antonio, TX
    6
    I didn't mention that, but yes, I did try that. Also tried resetting the network settings a couple of times in case some "crud" was being left behind from configuring a few times.
    One thing I'm wondering is if it's possible Apple is using two different chip sets due to the demand, and perhaps one of them has a driver issue?
    61156
    Jun 2011
    NJ
    28
    I had tried resetting the iPad a couple times, as well as turning off & unplugging the router to no avail.
    What finally solved it in my case was to change the security to WPA2 from WEP. I know that won't help in EwanG's case. I know in some cases the only way to solve was to replace the router.
    Mark
    116102
    Oct 2011
    USA
    4.3.5 Connectivity
    I'm assuming that the issue must be with iOS 4.3.5. This also startd happening on my iPhone 4 after I updated.
    135192
    Dec 2011
    Peoria, AZ
    i wish i knew what you just said, i'd love to try it !
    135192
    Dec 2011
    Peoria, AZ
    what is a "static" ip address. do i just write static or something. everybody seems to refer to this as a possible fix but nobody describes what it is.
  1. iPad 2 WiFi issues... Frustrating!!
    By iRockSteady in forum iPad Help
    Last Post: 03-25-2012, 09:12 AM
  2. Replies: 6
    Last Post: 01-20-2012, 07:33 AM
  3. WiFi/Bluetooth Onboard Diagnostics for Cars?
    By RAC in forum iPad General Discussions
    Last Post: 06-13-2011, 03:39 PM
  4. New, with wifi issues...
    By pmorin in forum iPad Help
    Last Post: 05-03-2011, 12:11 AM
  5. Intermittent Wifi issues with iPad 2 and WiFi
    By MarilynLockhart in forum iPad General Discussions
    Last Post: 04-24-2011, 11:11 PM
intermittent wifi issues with ipad2
ipad 2 dhcp issues
ipad 2 diagnostic tool
ipad 2 diagnostics
ipad 2 wifi issues
ipad dhcp issues
ipad diagnostics
ipad wifi diagnostics
ipad2 dhcp not working
ipad2 subnet mask wifi problem
renew lease doesnt show on ipad2
wifi diagnostic tools ipad
Tags for this Thread
