Hi everyone, any body knows why my mic is not working???? Plz
This is a discussion on Hi everyone, any body knows why my mic is not working???? Plz within the iPad Help forums, part of the Apple iPad Discussions category; Help plz...
Results 1 to 3 of 3
    84628
    Aug 2011
    Help plz
    119 times
    15,248
    105352
    Oct 2011
    Canberra, Australia
    Thanks, Tim. I tried your suggestion, but unfortunately, didn't work.
    My iPad microphone WORKS with the Recorder application, but NOT with SKYPE, nor with Talking Tom the Cat (as far as I know, I haven't tried the others). Note that it briefly worked with Skype when newly downloaded, then stopped working in the next log in. I deleted Skype and downloaded the latest version, same results: microphone worked with the test call, then later stopped working.
    Please help.
  1. Body Guardz Full Body Protection + Zagg Mate w/keyboard Possible?
    By iPad_Jedi in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-15-2011, 11:14 AM
  2. Did you See the new Google Body MAP on iPAD ?
    By peled in forum iPad General Discussions
    Last Post: 12-23-2010, 12:16 AM
  3. What do you think of the airport body scans?
    By SweetPoison in forum Off-Topic
    Last Post: 11-19-2010, 05:28 PM
  4. OK - I ordered a ZAG full body
    By DavidNM in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-30-2010, 03:28 PM
ipad microphone not working
ipod mic not working
ipod microphone not working
microphone on ipod not working
my ipod microphone not working
why is my ipod mic not working
why isnt my ipod mic not working
why isnt the microphone on my ipad keyboard working.
