Wi-fi connect problem
This is a discussion on Wi-fi connect problem within the iPad Help forums, part of the Apple iPad Discussions category; So I just got my shiny 64GB iPad2 set up but it refuses to connect to the 'net over my home wifi. As far as ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    61156
    Jun 2011
    NJ
    28
    So I just got my shiny 64GB iPad2 set up but it refuses to connect to the 'net over my home wifi. As far as I can tell the password for my network was entered correctly; I've got a checkmark next to the network name, and the wi-fi logo is being shown in the upper left with a good signal. But I cannot connect to the internet. I know the wi-fi is good; my iPod Touch works fine. Cellular data is turned off, so I don't see how that can be interfering
    Any ideas?
    Thanks,
    Mark
    32660
    3 times
    Feb 2011
    163
    Just asking...but are you connecting via a router? Is your router set up such that you need to enter the device Mac address to give permission? If so, do you access your router to set that in the wireless arena? I have my router set up so that I have to enter that info AND use the password also.
    119 times
    15,248
    Does your iPad connect to the Internet OK over 3G?
    61156
    Jun 2011
    NJ
    28
    I'm not using MAC filtering; as far as I know I've never entered the MAC address for any of the other devices that use the wi-fi - including 2 iPod Touches, a laptop, and netbook.
    Haven't tried the 3G and don't intend to unless it's necessary.
    Thanks,
    Mark
    119 times
    15,248
    I'll move this to the Help section; I think it will receive better attention there.
    61156
    Jun 2011
    NJ
    28
    Thanks Tim.
    Here's some more info. I tried it at work, in an area where there is an unsecured wi-fi connection. My iPod Touch connects to the internet no problem - this is a personal device and not company-issued so I know there are no security restrictions. Same issue with the iPad - it shows that it's connected to the wireless network, but when I try to browse in Safare it tells me it's not connected to the internet.
    Is there a Safari or other internet setting I'm overlooking?
    Thanks,
    Mark
    72357
    Jul 2011
    5
    Quote Originally Posted by Mark29 View Post
    Thanks Tim.
    Thanks,
    Mark
    Check to see if the iPad is getting an IP address. Is your router set up for DHCP?
    Cheers
    Chris
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Hi Mark - I'm not sure what your problem may be?
    But if not already done, I would power recycle both your modem & router (just turn them off or unplug each depending on the device) - power up the modem first & then the router.
    Also, restart the iPad - no harm done and might work? Good luck -
    61156
    Jun 2011
    NJ
    28
    Yes, the iPad is set for DHCP.
    I'll check try cycling the router when I get home, but this doesn't explain why I couldn't connect to an unsecured wi-fi. The Touch, which I had with me as well, had no issues.
    I don't have a separate modem & router - it's just one device though that shouldn't make a difference.
    Mark
    1520 times
    Walla Walla, WA
    15,430
    Go into your Settings > General > Reset, and then Reset Network Settings. That may help.
  1. I can't connect to my PC
    By xavier881 in forum iPad Help
    Last Post: 04-08-2012, 03:17 AM
  2. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
  3. Gv Connect Problem
    By Munky in forum iPad Help
    Last Post: 02-28-2011, 07:26 PM
  4. Ipad mail connect problem
    By galiano in forum iPad Help
    Last Post: 06-16-2010, 12:34 AM
  5. can't connect
    By vzx34 in forum iPad Help
    Last Post: 06-09-2010, 02:51 PM
ipad cannot connect to unsecured network
ipad self assigned ip
ipad self assigned ip address
self assigned ip address ipad
self assigned ip address on ipad
self assigned ip ipad
why my ipad will not connect to an insecure network
wifi has a self assigned ip address and cannot connect to the internet
