Ipad display problem
This is a discussion on Ipad display problem within the iPad Help forums, part of the Apple iPad Discussions category; You can restore your new iPad from a backup of your old one in iTunes. Make sure you have an up to date backup before ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    46070
    53 times
    Egremont
    979
    You can restore your new iPad from a backup of your old one in iTunes. Make sure you have an up to date backup before you exchange your old iPad by connecting it to iTunes and allowing it to sync.
  3. #12
    75207
    Jul 2011
    Florida
    6
    Quote Originally Posted by DefBref View Post
    Thanks so much for the help.
    Should I let them do this for me at the Apple store? or will this be easy for me to do myself?
    And, how can I make sure ALL of my passwords are totally erased off of this defective ipad2? Will clear history & cache do this? (or do I need to change all of my passwords?)
  4. #13
    46070
    53 times
    Egremont
    979
    No they won't be able to do it in store, you need to sync with your own itunes library.
    You can erase all contents and settings on the ipad (once you've done the backup).
  5. #14
    75207
    Jul 2011
    Florida
    6
    Done!
    I actually figured it out on my own. LOL. (I am actually starting to like Apple more than windows )
    I called the Apple store and they said they would exchange it - no problem at all. Now I just need to find an Apple store in the area that HAS a white 32G iPad2....that will prove to be more difficult.
    I will report back when exchanged.
  6. #15
    75207
    Jul 2011
    Florida
    6
    While I am waiting on the Apple store to replace(get them back in stock) my ipad 2 because of the “white spot” on my screen I thought I would post a couple of interesting articles I came across. (just a couple of MANY on Google when I typed in “white spot on my ipad screen”)
    Bright spot on screen
    https://discussions.apple.com/message/13226058#13226058
    If Your iPad 2 Has Display Problems, DO NOT Return It. Here’s Why
    http://www.cultofmac.com/if-your-ipad-2-has-display-problems-do-not-return-it-heres-why/87197
  1. Replies: 1
    Last Post: 02-01-2011, 10:36 AM
  2. Ipad JB problem.
    By nicksamba in forum iPad Hacking
    Last Post: 06-04-2010, 04:13 PM
  3. AIr Display Ipad app looks cool
    By jules in forum iPad Apps
    Last Post: 05-25-2010, 12:01 PM
  4. I did it!! Display anything from your iPad
    By Zip in forum iPad Hacking
    Last Post: 05-14-2010, 03:40 PM
  5. VGA display question
    By mediapad in forum iPad Help
    Last Post: 04-10-2010, 09:06 PM
ipad blank screen
ipad blank screen problem
ipad display problem
ipad display problems
ipad no display
ipad screen blank
ipad screen display problems
ipad screen issues
ipad screen problem
ipad screen problems
my ipad display will no longer show up on screen
screen problems ipad
