Connect iPad to a computer - Reboot cycle ~60 seconds later
This is a discussion on Connect iPad to a computer - Reboot cycle ~60 seconds later within the iPad Help forums, part of the Apple iPad Discussions category; I have a really strange issue. Here is my system info: iPad 3G + Wifi 16GB. Windows 7 Professional x64 iTunes (Latest version) Windows XP ...
Results 1 to 8 of 8
    5248
    May 2010
    Gold Coast, Australia
    • iPad 3G + Wifi 16GB.
    • Windows 7 Professional x64
    • iTunes (Latest version)
    • Windows XP Professional x86
    The problem I'm having, is if I plug my iPad into either of the above systems, it shows up in iTunes fine, and I can sync to it easily enough, but about 60 seconds after plugging it in, it reboots and gets into a reboot loop which can only be broken with a hard reset. Same thing if it starts up after a reset plugged in. Fine for 60 seconds, then restarts continuously.
    Oddly, if I start it up unplugged, or if I connect it to a powerpoint, it's fine and runs with no problem. This started seemingly randomly yesterday evening.
    Anyone else encountered a similar issue?
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Perform a restore on the ipad.
    if that doesnt work I would go to the apple store and exchange for a new one.
    I had one that started doing that, then the sleep/wake button stopped working all together as if it was always being held down. apple store said it was a defect and replace it with a new ipad.
    5248
    May 2010
    Quote Originally Posted by MikesTooLz View Post
    Great. Looks like I'm off to the apple store tomorrow. Thanks for the info though.
    EDIT: Hope they have one in stock, it'd suck if I had to wait until June 7.
    3626
    May 2010
    Smile
    Hey, try this if it helps. It helped me for sure.
    The problem is not in your iPAD, it is in on your PC in the BIOS.
    There is an option in the BIOS when you boot your machine for <USB VOLTAGE>. Try to find it.
    and when you do -
    - you will see 3 settings in there - Low, Medium, High. Most likely yours is set at HIGH. This is the cause of your iPAD rebooting every 60 secs.
    - Change this to MEDIUM, save bios and reboot. Now give it a shot.
    If that does not work, then flip it to LOW and repeat.
    Hopefully that will solve your issue. It did mine.
    If it works for you, do let me know.
    Enjoy!.
    baksharp.
    iPad Master!
    2051
    3 times
    Apr 2010
    home
    1,352
    Quote Originally Posted by Baksharp View Post
    and when you do -
    Enjoy!.
    baksharp.
    That is amazing, I have never heard of such a thing..... I hope the OP sees your advice and tries it...
    Bremen Cole
    iPad 1st Gen 16G
    5248
    May 2010
    Ok, I went into the Apple Store, one of the guys in there did a hardware-level restore and it seems to be fixed.
    Thanks for all your advice.
    Dav
    Dav is offline
    5524
    May 2010
    58
    Glad your issue has been restored and your iPad is back working.
    iPad Master!
    2051
    3 times
    Apr 2010
    home
    1,352
    Glad it got sorted out.... Lucky you live near an Apple store....
    Bremen Cole
    iPad 1st Gen 16G
  1. iPad 64GB WiFi problems (cannot connect)
    By BikerThomas in forum iPad Help
    Last Post: 12-27-2011, 03:53 AM
  2. Can you connect an iPad to a wireless audio receiver?
    By juliakatte in forum iPad General Discussions
    Last Post: 06-01-2011, 07:09 PM
  3. How to tether 3g ipad to computer.
    By qwerty in forum iPad General Discussions
    Last Post: 12-26-2010, 07:19 PM
  4. How to connect and use an USB external HD to the iPad
    By Ripplinghurst in forum iPad Hacking
    Last Post: 05-22-2010, 07:11 PM
  5. Apple fastracked Memeo Connect for iPad to App Store...
    By AbblePC in forum iPad General Discussions
    Last Post: 03-31-2010, 04:09 PM
apple ipad pc reset
connect ipad to pc wireless windows 7
how to fix the constantly restarting ipad
how to fix the constantly restarting with ipad.
how to reboot ipad from your computer
howto reboot my ipad from computer
ipad causes pc to reboot
ipad continuous reboot
ipad reboot cycle
reboot ipad from computer
restart ipad from pc
when i connect my ipad to my pc, the pc restarts
