Won't charge & won't connect to iTunes.
This is a discussion on Won't charge & won't connect to iTunes. within the iPad Help forums, part of the Apple iPad Discussions category; I have been fighting this for a few weeks. One time for about a day my iPad did charge and did sync, but it stopped ...
Results 1 to 8 of 8
    74031
    Jul 2011
    5
    Question Won't charge & won't connect to iTunes.
    I have been fighting this for a few weeks. One time for about a day my iPad did charge and did sync, but it stopped again about five days ago. I have tried other official cables and official charge pucks. All were the 10w/2A official variety. Strangely, the iPad will charge very slowly on an official charger if the iPad is is turned completely off. I have tried both reset methods, from on and from off. Any ideas besides a factory reset?
    By official, I mean the official and correct Apple products.
    I get the "Not Charging" notification.
  2. #2
    13576
    218 times
    Aug 2010
    Western NY state (USA)
    5,127
    Sorry to ask the stupid question, but: You are charging via the wall socket, not the computer, right? Cause most computers don't push out enough power to charge the iPad, even with the iPad charger.
    If that's a yes, then my only suggestion, given that you said you are using the 10W/2A iPad charger, is to take the charger and the iPad to the Apple store. Take the charger to tell them it's not working (they should replace it) and the iPad to test the new charger to make sure that it IS the charger.
    Cause something is defective there - I'm hoping that it's your charger, not your iPad.
    Black 64GB WiFi/4G iPad3 (iOS 5.1.1; jailbroken w/Absinthe 2.0) & black 64GB iPhone 4S (iOS 5.0.1; jailbroken w/Absinthe 1.0)
  3. #3
    74031
    Jul 2011
    5
    Yes Indeed
    Yes, iPad wall chargers. Tried two different iPad wall chargers and cables as I mentioned. My friend's iPad (which was my old 32gb version) syncs and charges fine with either cable or charger. I noticed in many other threads about this problem ppl usually used an iPod or USB chargers that didn't have the iPad's required power output. So I am trying to be clear about that. There isn't an Apple Store within about 500 miles of here. I was hoping that someone had something new to suggest.
  4. #4
    74031
    Jul 2011
    5
    Need help before I drive 500 miles to an Apple Store
    Would doing a factory reset make any difference?
    Also, I have purchased apps on my iPad that are not backed-up to iTunes yet, will I be able to get those again without paying again?
  5. #5
    iPad Enthusiast!
    63426
    Jun 2011
    56
    Quote Originally Posted by biffsbiz
    You can redownload them at any time in the app store app by selecting the Purchased option. Same with iTunes.
    At this point, I would try anything and everything there is to try. Including the power button/home button option to reset and full restore via iTunes. Anything to narrow it down from a software issue to a hardware issue. .
  6. #6
    74031
    Jul 2011
    5
    Completely Reset iPad
    I finally completely reset the iPad. It has nothing on it. It wants me to connect it to iTunes, but it still won't get recognized by the computer or, of course, iTunes.
    Trying to charge it with the correct (10watt) puck and cable, it no longer says "Not Charging", it says nothing, although the iPad does beep when I plug the cable into it.
    I will try charging it overnight, with the iPad completely off. I don't expect any change though.
  7. #7
    iPad Enthusiast!
    63426
    Jun 2011
    56
    Sounds like hardware issues to me. I'd call Apple and explain your situation and see what they can do to rectify the problem.
  8. #8
    74031
    Jul 2011
    5
    Quote Originally Posted by ALcH3Mi5T View Post
    Yes. I tried to connect the iPad to a different computer. Failed.
    I called Apple and they went through all the steps I'd already done and decided that it needs replacement.
    Express replacement won't work for me because I'm remote and don't have a street address. They won't ship to my Post Office box. My Post Office box is only about a 100 mile round trip, but Apple won't ship the replacement there.
    So, I need to drive 500+ miles to one of the 4 Apple Stores in the Phoenix area for a replacement. Then I need to drive 500+ miles back home.
    Very inconvenient and expensive for a warranty replacement. Why don't they like U.S. Mail, fer chrissakes?
Sponsors
  1. Suspicious Visa Charge From iTunes
    By pdmike in forum iPad General Discussions
    Last Post: 03-24-2012, 08:38 PM
  2. Cannot connect to the itunes or app store
    By akammer in forum iPad Help
    Last Post: 07-08-2011, 09:59 AM
  3. Cannot connect to iTunes
    By tanja cronje in forum iPad Help
    Last Post: 05-31-2011, 04:01 AM
  4. Cannot connect to itunes
    By 0pawwap0 in forum iPad Apps
    Last Post: 04-16-2011, 09:53 AM
  5. Jailbroken iPad Won't Sync With iTunes or Charge
    By hotphoenix in forum iPad Help
    Last Post: 11-25-2010, 07:38 AM
fix ipads that don't connect to itunes'
ipad 3 won't connect to itunes
ipad charges but won't sync
ipad doesn't connect to itunes
ipad won't charge or connect to itunes
ipad won't connect to computer or charge
ipad won't connect to itunes
ipad won't connect to itunes not charging
iphone 4 cannot charge and cannot connect to i tune
iphone 4 cannot connect to itunes and charge
iphone 4 won't connect to computer or charge
iphone 4 wont charge or connect to computer
iphone 4 wont charge or connect to itunes
iphone 4 wont charge or sync
iphone 4 wont connect to computer or charge
iphone 4 wont turn on or charge or connect to itunes
iphone 4s not connecting to itunes or charging
iphone 4s wont charge or connect to itunes
iphone wont charge or connect to itunes
mt ipad won't connect with itunes
Tags for this Thread
