Results 1 to 3 of 3
    82557
    Jul 2011
    Burlington, Ontario Canada
    Streeming audio stops after 1 minute
    Recently two apps started to pause while playing approx. 1minute after start. The audio and video will continue to pause, again every 60 seconds.
    The two apps had worked for months no issues.
    The two apps are MLB.com and Netflix.
    Has anyone encountered the same, what is the cause and is there a fix?
    116 times
    15,249
    82557
    Jul 2011
    Tim,
    Outstanding!
    Option two, (press &hold power off then on)worked like a charm...
    Many thanks!
    Dan
  1. Will Skyfire stream audio from flash audio player?
    By wahoowad in forum iPad General Discussions
    Last Post: 04-03-2011, 03:54 PM
  2. New App Brings 5 Minute Yoga to the iPad
    By Maura in forum Apple iPad News
    Last Post: 10-25-2010, 02:28 AM
  3. Who Waited Until Last Minute to Still Get Unlimited 3G
    Last Post: 06-07-2010, 06:07 PM
  4. Ipad last minute hardware change?
    By iDan in forum Apple iPad News
    Last Post: 03-13-2010, 10:17 PM
  5. Last minute Tablet Photos leak to Engadet
    By iDan in forum iPad General Discussions
    Last Post: 01-27-2010, 08:19 AM
ipad audio stops
ipad audio streaming stops
ipad mp3 player stop streaming
ipad stops streaming music
ipad, streaming stops after a few minutes
iphone 5 audio stops after a minuite when streaming radio
iphone 5 stops streaming audio after a minute
ipone 5 audio stops with netflix
netflix ipad stops every minute
netflix on ipad stops every minute
streaming audio stops on ipad
video stops after 1 min and the player closes
