Iphone configuration utility not running on my PC
This is a discussion on Iphone configuration utility not running on my PC within the iPad Help forums, part of the Apple iPad Discussions category; For some silly reason iPhone configuration utility is not running o. My PC , I need that to instal whatsapp on my pad 2. Done ...
Results 1 to 8 of 8
    81063
    Jul 2011
    23
    Done everything from uninstall to restore my PC to an earlier date and then instal the program again....nothing.
    Can anybody help me in here? And also, there is any other program to substitute iPhone config utility?
    Thanks to all in advance
    Sent from my Ultra Jailbroken iPad 2
    81168
    Jul 2011
    152
    Did you make sure you have the correct version 64 bit or 32 bit)?
    Sent from my iPad 2 using iPF
    81063
    Jul 2011
    23
    In the apple page there is only one version for windows... But it can be that...
    162131
    Feb 2012
    I come from a land down under when women glow & men thunder
    The only solution I have found so far is to login as the Windows Administrator & then delete your user profile. It's a pain, but it resolves the issue. **Warning, make a copy of your data saved to your user profile prior to deleting**.
    159462
    16 times
    Jan 2012
    194
    Quote Originally Posted by devans
    That's a bit overkill usually. It should be sufficient in most cases to delete C:\users\<username>\AppData\Local\Apple Computer\iPhone Configuration Utility and all folders starting with iPcu.exe under c:\users\<username>\appdata\local\Apple_inc
    The first folder contains the log file (which should be looked at as it may tell why it's failing to start) and the later contains the user configuration settings which is usually the culprit. In the few rare cases where I've had it fail to start due to registry issues the log file indicated which registry key was corrupted and deleting that key allowed it to start.
    162131
    Feb 2012
    I did some further research & found a much easier solution. The ipcu log file displays the following error when attempting to open iPCU:
    [2012-02-08 14:55:12.5312 iPCU] Debug: Loading Apple Application Support from 'C:\Program Files\Common Files\Apple\Apple Application Support\'
    [2012-02-08 14:55:12.5312 iPCU] Debug: Loading Apple Mobile Device Support from 'C:\Program Files\Common Files\Apple\Mobile Device Support\'
    [2012-02-08 14:55:13.2968 iPCU] Error: Exception from OnStartupInitial: Object already exists.
    It appears to be related to .NET & authority to access an RSA key container. I deleted the
    C:\Documents and Settings\%username%\Application Data\Microsoft\Crypto\RSA directory & was then able to successfully launch iPCU again.
    283995
    Mar 2013
    qqqqq
    Iphone configuration utility not running on my PC!
    I deleted the "RSA" directory from the location C:\Documents and Settings\%username%\AppData\Roaming\Microsoft\Cryp to\RSA directory & was then able to successfully launch iPCU again.
    283995
    Mar 2013
    qqqqq
    Thanks. It helps.
  1. JB Upgrade Utility
    By iNb in forum iPad Hacking
    Last Post: 10-10-2012, 01:43 AM
  2. Preserving app and folder configuration
    By dakili in forum iPad Help
    Last Post: 05-15-2011, 05:05 AM
  3. Using configuration utility for company wide deployment
    By dayanks101 in forum iPad General Discussions
    Last Post: 02-15-2011, 08:09 AM
  4. iPhone Configuration Util Failure
    By r3g3x in forum iPad OS
    Last Post: 09-08-2010, 09:50 PM
  5. Language configuration
    By mvanvalkenburg in forum iPad Help
    Last Post: 04-07-2010, 07:12 AM
ipcu not working
iphone configuration utility does not start
iphone configuration utility failed to locate apple application support
iphone configuration utility failed to locate apple mobile device support
iphone configuration utility not launching
iphone configuration utility not opening
iphone configuration utility not starting
iphone configuration utility not working
iphone configuration utility not working windows
iphone configuration utility will not open
iphone configuration utility will not start
iphone configuration utility windows not starting
